RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Best first KIT PLANE??? (https://www.rcuniverse.com/forum/beginners-85/10248436-best-first-kit-plane.html)
whoareyou310 01-08-2011 12:59 PM
I've built several ARF's and I would like to build a nice first kit with very easy instructions. Any recommendations? A .40 size would be ideal, probably a trainer just for simplicity sake. thanks for the suggestions.
Lone Star Charles 01-08-2011 01:13 PM
RE: Best first KIT PLANE???
I've built several of the Great Planes PT series over the years.  Easy to build, good instructions and excellent support.  The planes have been around for a lot of years.  I have built a PT-20, two PT-40's and one PT-60.  All were good flyers, cheap and easy to repair.
scooterinvegas 01-08-2011 01:38 PM
This is a great first kit, Four Star 60. Super easy to build, lots of people here on RCU to help and flys like a low wing trainer. In my opinion, there is NO advantage to building a 40 over a 60.
http://www.sigmfg.com/IndexText/SIGRC73.html
http://www.hvrcc.com/uploads/3/5/1/1...50125_orig.jpg
http://t0.gstatic.com/images?q=tbn:5...u66620.jpg&t=1
http://www.hooked-on-rc-airplanes.co...g-21254645.jpg
goirish 01-08-2011 01:41 PM
Hey whoareyou310, where in MI are you. Cold here in the south central part.
Mk23socom 01-08-2011 01:57 PM
I really liked my SIG LT .25 build.. hung a .46 on it and I can fly for 25 mins on a tank... fun build and flies great.. Also have an LT .40 I bought from a guy that couldnt fly anymore.. it also has a 46 on it and it isnt as fast but still flies great..been up as long as 18 mins with that one.. both great stable craft!
OzMo 01-08-2011 02:04 PM
1 Attachment(s)
+1 on the 4*
Any Sig kit is good. The 4* series have been favorites for a while for good reasons. The Sig LT 40 is the prefered trainer for our club and many others.
If you are wanting a trainer as an everyday flier ( I would not be without one) build an LT but only use 50% of the recomended dihedral for better inverted performance.
Some add a bit of rudder also. I also changed the tail shape but just because my kid asked me to :D
mike109 01-08-2011 02:19 PM
G'day
Another vote for Sig Kits.
I currently have the following planes built from Sig kits and all are great -
Kadet Senior (excellent large slow three channel trainer but lots of building in it), Kadet LT-25 (very easy build, flies really well with a 30 four stroke), Four Star 40 and 60 (nice to fly and super easy to build if you follow the instructions), Somethin' Extra ( great fun with 30% expo to tame those large ailerons).
I also have a couple of Sig ARFs but I think the kit versions are better as you can cover them better than the ARFs are.
Enjoy your build. I am sure you will.
Mike in Oz
oldtyme 01-08-2011 03:30 PM
scooterinvegas...........I would agree with you but I don't know if the 4*'s are available. I tried to buy a 4* 60 late last year and they were out of print with no availability forcasted. The BTE Venture 60 was recommended to me as an alternative so I bought one and it looks great. I haven't started to build it yet but as I researched this model I found out that it was designed by the same fellow that designed the 4* 40 and 4*120 and it is said by Bruce himself that he incorporated the top 10 improvements that he wanted to make in the 4* series. I can tell you that the wood and precut parts are the best that I have ever seen. This might be a good alternative if the OP cannot get a 4*
Phoenixangel 01-08-2011 04:31 PM
Goldberg Tiger 2, you will love the plane, the kit is great for a first build. http://www3.towerhobbies.com/cgi-bin...?&I=LXYXF7&P=0
Gray Beard 01-08-2011 05:12 PM
ORIGINAL: scooterinvegas
Scoot, the advantage is the 60 is easier to see. Other then that??? I like them both but have been using the 60 as a training aid for new builders. Last year I finally built one with a full wing, I thought the clipped wing was a floater!! I also like the two aileron servos if the new builder has a radio that will handle it. I don't like Ys but if all you have is a four channel radio then the Ys do work. The 4* isn't too far removed in flight from a trainer, a good instructor may even like it better?? I have never tried it but I think it would be nice for a change.
Lake Mead was great today. Those weeds and rocks at the end of the runway kept trying to eat my planes though. My Bad!!!!!!!!:eek:
SJNason 01-08-2011 05:41 PM
I can second the tiger II nice flier and a good first kit.
scooterinvegas 01-08-2011 05:49 PM
ORIGINAL: Gray Beard
I took a buddy out to lake mead a couple of weeks ago to give him his first buddy box flight..... with my 26cc Ultra Stick Lite! LOL
He did two 20 min flights, and he did GREAT. Picked up the basic right stick turns (LH&RH), and made the correct adjustments when the Stick was coming toward us. He even learned to kept orientation when doing rolls and loops. Trainer???? We dont need no stinking trainer!!!
:D
Gray Beard 01-08-2011 06:58 PM
:D
:):):):):) My thinking too. I have flown there several times over the years without problems but I really need to put some of those slower downer things on my wheels. My pattern plane just comes in too hot and it and my Extra just love to do those long roll out thinger ma jigs. There be big rocks behind them big bushes!!!:D I finally pulled out the hots and all was well until the bung got blown out or came loose. I'll look things over and make some changes. Looks like it's still going to be a while for the Lake Bed to dry out. We had a very nice breakfast at Rail Road Pass too!! No specials on weekends?? I didn't know today was the weekend?? Senior Moment.
OP, build what scooter says!!! If not then get a Stick!!
Gene:):)
ohnoucdat 01-09-2011 03:52 AM
TRy the Sig SSE, open box, throw in bottle of glue, close box, shake box, open box, there's your new plane.
rrragmanliam 01-09-2011 08:59 AM
I can think of one. If all you have on hand is a 40-46 engine !
rrragman
scooterinvegas 01-09-2011 09:14 AM
ORIGINAL: rrragmanliam
Your looking at it all wrong. If you only have a 40-46 engine, the advantage to building a 4*-60 is you are completely justified for buying a new 95AX for it! :D
scooterinvegas 01-09-2011 09:55 AM
The "CASINO SPECIAL" at the Rainbow on Water St is only $1.89. Two eggs, bacon or sausage, hash browns, toast or biscuits & gravy. I think on the weekends its $2.25. Breakfast with a cup of joe for under $4 with tip and your ready to fly! (I know, Im cheap) :D
Gray Beard 01-09-2011 10:53 AM
The ''CASINO SPECIAL'' at the Rainbow on Water St is only $1.89. Two eggs, bacon or sausage, hash browns, toast or biscuits & gravy. I think on the weekends its $2.25. Breakfast with a cup of joe for under $4 with tip and your ready to fly! (I know, Im cheap) :D
Not a clue where thay is at. We do drive by the RR Pass though. Can look out the window at the lake bed to see how it is doing. The price of the breakfast wasn't bad but I was in a bit of sticker shock over the coffee and orange juice. I'm not cheap, well, OK, maybe just a bit, I'm just on a very fixed income. Where the heck is the Rainbow? Don't have a clue where Water St. is either. If it's on the way to the lake then it sounds like my new favorite. What a fantastic day!!! I should be out flying again instead of working on my messed up planes. At least I got them all back home in one piece. Some real ugly crashes out there yesterday.
psb667 01-09-2011 10:53 AM
Sig is usually a good build.
scooterinvegas 01-09-2011 11:24 AM
ORIGINAL: oldtyme
Their out there, you might have to look on line maybe. I bought another 4*-60 kit from my LHS 2 weeks ago.
mcdanman2003 01-09-2011 11:39 AM
I like the way this man thinks.
carrellh 01-09-2011 02:37 PM
As of January 9, GravesRC has some SIG 40 size kits in stock; that are considered good first builds
Four Star 40 http://www.gravesrc.com/SIG_FOUR_STAR_40_p/sigrc44.htm
Somethin Extra http://www.gravesrc.com/SIG_SOMETHIN..._p/sigrc76.htm
They also have the Goldberg Tiger 2 http://www.gravesrc.com/GOLDBERG_TIG...p/gpma0966.htm
Gray Beard 01-09-2011 04:33 PM
Give SIG a call. Just before Xmas they started getting in a lot of there kits. If it isn't in stock then wait until it is before you order or it could be a long wait.
Navy18 01-10-2011 09:47 AM
1 Attachment(s)
Just a vote for the Telemaster; what a great kit with a plane that flies as good as any trainer.... a real nice project.
jeffie8696 01-10-2011 10:49 AM
SIGkits. LT-25 will not be in stock till Apr.
They have some LT-40s now, as in right now as I am typing.
and Something Extras are expected late Jan.
OzMo 01-10-2011 03:18 PM
:) I like the way he thinks!! Although both the 4*40 and 4*60 are similar it is generally acknowledged the 60 flies a bit better. IMHO
whoareyou310 01-10-2011 07:19 PM
thanks for the info everyone
CGRetired 01-11-2011 05:48 AM
ORIGINAL: OzMo
Granted, the 60 "flys better", but that goes without saying that any of the 60 "upgrades" fly better than their smaller counterparts (Goldberg Tiger II and the Tiger 60, for instance), and that's not necessasrily because it's a better flying plane, it's mainly because it's larger, more visible, and handles a bit more smoothly and a bit less reactive than their smaller counterparts. And, as Gray Beard said, it has good visibility, important to us old codgers and for those recently solo'ed pilots looking for a second plane to hone their contol. It's great to see what the plane is doing when fed input from the transmitter.
I've owned the Four Star 40 and the Tiger 60 as well as a Tiger 120. The Four Star 40 was more agile than the Tiger 60, but again, that was due to the size and weight differences. BUT, I will say this: these are fine flying planes for anyone seeking a good, solid second plane.
My Tiger 60 originally had an OS 62, then later on I put on a Super Tigre 75 with a tuned pipe. Personally, I think the OS .95 two stroke is a tad much for that plane Based on the performance of my OS .75 on the Skylark 70, I'd opt for that engine. But, if a 90 size engine is desired, I'd go to an OS four stroke, which i've also flown on a Tiger 60 and it was very reactive, even for a 60 size plane!! Nice flyer, in other words. Very capable.
CGr.
bigdanusa 01-11-2011 07:08 AM
1 Attachment(s)
ORIGINAL: whoareyou310
Well, if you've (assembled) several ARF's I assume you have some flying experience.
I would recommend the Sig "Somethin" Extra with a .46 size engine on it. It almost falls together, easy to follow instructions and is fun to fly.
Unfortunately, I lost mine after only 25 flights in a mid-air collision where 2 other planes were flying the oval the opposite way.
big dan
CGRetired 01-11-2011 07:40 AM
I have the Little Something Extra that I converted to electric. It is a real performer!! Nice plane, good handling qualities too.
CGr.
