RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   How to weigh a plane (https://www.rcuniverse.com/forum/beginners-85/1025916-how-weigh-plane.html)
lslewis 08-05-2003 07:37 AM
I want to be able to measure the weight of small parts, like the rudder or a chunk of balsa all the way up to the completed bird.
Is there a single scale available that will measure from less than an ounce to a dozen lbs or so? Balance beam? How do you do it?
Recommendations will be appreciated.
twostroker 08-05-2003 10:57 AM
Digital fish scale
Hang it from some part of the plane that WILL support it's weight, like the landing gear, or prop.
DBCherry 08-05-2003 11:25 AM
Gives you a close weight for the entire plane, but not so good for weighing a "chunk of balsa". :rolleyes:
I have a scale that I bought at Staples for about $30 to $40. It's pretty accurate down to about 0.1 ounce, which may not be good enough for a small piece of balsa, but it will also weigh up to 12 to 15 pounds, so....
Dennis-
Montague 08-05-2003 03:25 PM
If you paid $30-40 for a scale with a .1 oz resolution and max of around 12lbs, you did really well.
You can find a selection of scales at most office supply stores as postage scales. But they usually have a tradeoff between resolution and max weight and cost.
My scale is acurate to 5grams or 1/4oz depending on the setting, and I forget the max, but I've put 6lb planes on it with no trouble. So It's not that useful for a small bit of balsa, but if I put on a pile of balsa, I can get a general idea of what's going to happen
mtthomps 08-05-2003 03:52 PM
When I want to weight the entire plane, I place it on my digital scale nose down with only the prop shaft touching. I then balance it straight up like this and read the scale.
