RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   NewB with Triton2 EQ Needs Help (https://www.rcuniverse.com/forum/beginners-85/10281364-newb-triton2-eq-needs-help.html)
Rockabilly Basher 01-22-2011 07:01 PM
Hey there,
For all that are curious - Iended up getting the DX-7 and couldn't be happier. But what I should have done is also asked about chargers. Instead, Iwent flying today (brought home 1 broke and 1 intact plane so I'm getting better) and started talking to a pro about charging and lipo's and stuff. He brought over his little doo-dad and saw that one cell was lower than 3v and immediately brought over his balancing charger with lcd readouts and everything. I have seen the videos about how these batteries blow up, so now Iwas worried. Within a couple minutes my battery was balancedand all was well, butImade the decision to goto the hobby shop right then and get a "good" charger.
The guyhad a Hyperion and the Triton2 EQ.He said the Triton was the latest and greatest and would accept a return on the new Hyperion duel if I didn't like it. Ileft the shop with a positive attitude knowing Icould now take the guess workand risk of using the cheap chargers that come with RTF flyers.
Got home, set it up and programmed the memory for my 4 batteries, then went to check the balancing and found out I couldn't do it. It didn't come with the patch cord that goes from thebatteries output (black and red) to bannana clips that goin the unit.This meant another trip to the HS for the cord, but I felt Icould at least check the cellswith the balancer hooked up, but this was not the case.
Then I figured I would look online to see ifothers had figured it outand all Isaw were posts about how crappy this charger was and how bad the cust. service was.
Should Itry to make this one work, or just return it for the Hyperion?
Rockabilly Basher 01-22-2011 07:14 PM
RE: NewB with Triton2 EQ Needs Help
UPDATE -
Just read another thread and they said both square buttons needed to be pushed to see each cells readings.  I didn't see this in the instructions which is why I probably missed it.  So I hooked up each battery and they were all ballanced to within a couple hundredths of a volt, which is why (I'm assuming) it didn't go into balancing/discharge mode.  Still need to get the charging cord for it, though.
PS - I thought I read somewhere that lipo's are one way batteries - charge/balance through one lead and provide power/discharge through the main black and red lead.  is there any truth to this?
jester_s1 01-22-2011 11:36 PM
I have the regular Triton EQ and am happy with it. I certainly wouldn't call it bad quality. I've had a Hyperion before and can honestly say it's the most intuitive piece of equipment I've ever had for RC. I didn't even need a manual. It's not made any better though.
As for the battery leads: Normal charging goes in through the main 2 wire lead. The balance connector (little wires) is there so the charger can put a small discharge load on your high cell to let the others catch up. There are chargers that charge through the balance connector, charging each cell individually. One isn't better for your batteries than the other. It's just a different way of getting to the same place.
scooterinvegas 01-23-2011 01:18 AM
I like my Triton2 EQ, works great. When its cold, the display is a little slow though.
