Motor Mount Question
I am converting a nitro powered Air boat to electric. Can someone tell me what the hole circle or measurement across the mounting holes on the Park E-flite 450 Brushless motor is. I am waiting on the motor and would like to build the mount.
Thanks, John (Retired Machinist) |
RE: Motor Mount Question
Park 450 Brushless Outrunner Motor, 890Kv
Specs Type: Brushless outrunner Size: Replacement for 370 or 400 Bearings or Bushings: One 4 x 8 x 3mm Bearing, and One 4 x 9 x 4mm Bearing Recommended Prop Range: 9x6 to 11x3.8 Slow Flyer or 10x5 to 12x6 Electric Voltage: 7.2–12 RPM/Volt (Kv): 890 Resistance (Ri): .20 ohms Idle Current (Io): .70A @ 8V Shaft Diameter: .16 in (4mm) Overall Length: 1.30 in (33mm) Weight: 72 g (2.5 oz) Overall Diameter: 1.10 in (28mm) Diameter: 1.1 in (28mm) Length: 1.3 in (33mm) Continuous Current: 14A Maximum Burst Current: 18A for 15 seconds Cells: 2–3 Li-Po or 6–10 Ni-Cd/Ni-MH Speed Control: 20A brushless ESC Needed to Complete 20A brushless ESC 9x6–11x3.8 prop 2S–3S 1200–2100mAh Li-Po Battery |
It's best to wait for the motor. It comes with an X-mount, and is easy to install.
| All times are GMT -8. The time now is 05:45 PM. |
