Automatic bomb release ???
Hi there,
I'm kind of fresh to all this stuff, but I was wondering if there is a way to automatically release the bomb, with some sort of timed mechanism somehow. Without using radio commands. I'm setting up an aircraft glider. Any ideas would be appreciated. cheers.<br type="_moz" /> |
RE: Automatic bomb release ???
Is this a radio control glider?
There are battery powered timers and solenoids that could probably do this. But, before going too far, you should contact the British Model Flying Association http://www.bmfa.org to be sure there are no regulations against it.
Thank you for your suggestions,
No, it is not radio controlled and I'm not building like a proper big model aircraft. |
Could you please specify what it is exactly I would need, to go about building this. I have a good enough budget.
And/Or any online stores that supply such products. Cheers.<br type="_moz" /> |
i don't know if we should even be helping you, you seem suspicious at the moment
| All times are GMT -8. The time now is 11:43 AM. |
