RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Hinge gap (https://www.rcuniverse.com/forum/beginners-85/10497889-hinge-gap.html)
bryris 05-02-2011 04:56 PM
Hinge gap
On my LT-40, I had an elevator CA hinge break on me. I decided to cut out the remaining CA hinges and got some plastic hinges, cut new slots and reinstalled. Works great now. However, I notice in flight there is a slightly strange noise that is new. I am thinking that the gap between the rear of the horizontal stab and the elevator is a bit wider now due to the hinge pins, etc and air might be slipping through that slot and causing a bit of flutter. I was advised that a good repair would be to get some ultracote and fairly loosely iron a thin piece along the top and bottom of that hinge gap to keep the air from slipping through it. Is that sound advice? Is there a better way to handle this?
scooterinvegas 05-02-2011 05:09 PM
RE: Hinge gap
I would use clear packing tape. KISS rules rule.
Gray Beard 05-02-2011 05:33 PM
RE: Hinge gap
One of the guys bought a roll of clear Ultra just for that reason, it works grreat for sealing the gaps.
MinnFlyer 05-02-2011 05:37 PM
RE: Hinge gap
And you only need to do one side (usually the bottom just to hide it)
SeamusG 05-02-2011 06:44 PM
RE: Hinge gap
Yup - what GB and MinnFlyer said. I've tried hinge tape with a glow engine - didn't last long. Where I've had more than one color of film across the hinge line I use clear Ultracote. If it is one color then I just use matching color film.
If glow powered and the exhaust exits on top of the wing - cover the top to protect the backside of the seam from glow fuel. If it exits below the wing - then do the bottom.
Gray Beard 05-02-2011 07:12 PM
RE: Hinge gap
I don't need to use it very often the way I cover but when I need some I always have someone to borrow it from. Bottom only is needed but if you do the top too it helps the end of day clean up.
cutaway 05-03-2011 10:00 PM
RE: Hinge gap
The relative stiffness of CA hinges is probably a vibe dampening effect to some degree. A seal line is generally a good thing though. Abbott and Dohenhoff ( a classic reference on subsonic aerodynamics) published data showing ~20% efficiency gain for hinged surfaces that were sealed.
