Muffler
Is it ok for the muffler to touch the fiberglass engine cowl? Will it burn?
RE: Muffler
You really want to try and avoid it touching the cowl. It won't burn the fiberglass. But the vibrations will destroy the cowl pretty quickly over the period of a few flights. Especially if we are talking about most "fiberglass" cowls in today's ARF's. The fiberglass is pretty thin and won't stand up long
Ken |
RE: Muffler
Ken is correct...all you have to do is cut a hole in the cowl just big enough for what ever part is touching the muffler....you don't have to cut a huge hole for the whole muffler.....
Make sure to avoid square corners as cracks can form at the corners |
RE: Muffler
Ok thanks guys. I will fix it.
| All times are GMT -8. The time now is 08:39 AM. |
