wingspan?
what is the wingspan range for a parkflyer?
RE: wingspan?
I don't think there is an actual range for wingspan for park flyers or any other type aircraft. Usually, when the manufacturer says "park flyer" then that's what it is. For instance, you can't say 36 inches because the Little Something Extra has that wing span but is not a park flyer, yet a foamie that is very light, with a 36 inch wingspan may be considered a park flyer and designed to fly in more confined spaces (ball parks, soccer fields, and so on) than something that really needs a runway. A 40 size glow trainer is a trainer as is a 60 size glow trainer. Both are glow powered trainers, but one is larger than the other.. a wider wingspan and a bigger engine.
CGr. |
RE: wingspan?
oh okay thanks. so it doesn't really matter about the wingspan of the plane as long as it can be flown there without trouble?
RE: wingspan?
also, i have been seeing many planes i want that have a 27mhz transmitter. would it be fine to get one with a 27mhz?
RE: wingspan?
It is more a matter of weight and flying speed than wing span I think.
Tom |
RE: wingspan?
ORIGINAL: noveldoc It is more a matter of weight and flying speed than wing span I think. Tom No more than 2 pounds and a speed of no more than 60 MPH. |
RE: wingspan?
okay thanks guys.
RE: wingspan?
We all just learned something. ;)
CGr. |
RE: wingspan?
hmm....so a flyzone skyfly max is 1.6lbs. idk the speed of it, but i am thinking it would be fine for some flying around my middle schools field.
RE: wingspan?
My brother has a Skyfly 2, which is quite smaller than the MAX, and it needed a rather large area. I'd say, four football fields grouped together. However, he was learning and needed the space to give himself time to set up for landing approach. If you are a little more experienced than a newcomer, than you may have enough room to fly it in a single football field. I might add, that the Skyfly 2 is pretty quick for a small electric 3 channel plane. I believe it has a Brushed 380 pusher motor.
~Noah |
RE: wingspan?
okay thanks. this would be my very first airplane. i guess i will join a local club then if i decide to fly planes over helis. (still deciding since cars give me no thrill whatsoever).
RE: wingspan?
ORIGINAL: electricrc68 hmm....so a flyzone skyfly max is 1.6lbs. idk the speed of it, but i am thinking it would be fine for some flying around my middle schools field. |
RE: wingspan?
Over here, the council defines a 'parkflyer' (ie one we are legally aloud to use in a park) as electric, under 1kg (2.2lbs) and under a meter wide .... that said, there is a really nice little underutilized park round the road from home where I fly my 3.6kg, 1.35mtr rotor diameter nitro burning heli often ..... only time I ever had a council worker come up and ask me about it was to state how nice it was, and just how much was it to buy one!! ;)
RE: wingspan?
ORIGINAL: CGRetired ORIGINAL: electricrc68 hmm....so a flyzone skyfly max is 1.6lbs. idk the speed of it, but i am thinking it would be fine for some flying around my middle schools field. ;) |
RE: wingspan?
pm lingo. :eek:
RE: wingspan?
its modern day youngster talk CG. :D
RE: wingspan?
ORIGINAL: electricrc68 okay thanks. this would be my very first airplane. i guess i will join a local club then if i decide to fly planes over helis. (still deciding since cars give me no thrill whatsoever). It must be flown in zero wind which is the only real drawback, except, when you are just starting out, zero wind is your friend. Good luck |
RE: wingspan?
ORIGINAL: electricrc68 its modern day youngster talk CG. :D CGr. |
RE: wingspan?
ORIGINAL: electricrc68 also, i have been seeing many planes i want that have a 27mhz transmitter. would it be fine to get one with a 27mhz? <div style="margin: 0in 0in 0pt">I know this is an old thread, but this may be helpful for anyone who may be looking at buying a ready to fly park flyer.</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt">In the US, both 27MHz and 49MHz are commonly used for toy-grade radio controlled vehicles.In my opinion the 27MHz band should not be used on any R/C that has the potential to cause personal injuries or property damage.If it flies I say 27MHz should NEVER be used.On the ground if it goes fast enough to hurt your foot if it hits you at full speed or if it is expensive and you don’t want it to drive it self into the road, lake or some other potentially hazardous area stay away from 27MHz.Though FM is safer than AM, both are VERY VERY susceptible to RFI (radio frequency interference).</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt">I can go into great detail as to why 27MHz is a bad idea, but for the sake of this forum and to keep this as short as possible I will forego the tech talk and just say this.The guy at the toy store or hobby shop may tell you that there is no interference problems but he is wrong, misleading you or just un-educated in the matter.</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt">CB Radios used by truckers and citizens all over the USA run on 27MHz and when hooked up to a 10 meter radio amplifier (made to work on 28MHz and illegal to do) it causes “splatter” from 25Mhz to 30Mhz.</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt">Anyone old enough to remember the days of watching T.V. using an antenna may remember the occasional interference.The picture gets messed up and the audio goes wacky.Some times you can even make out what the CBer is saying!</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt">Trust me when I say a CB can and WILL take over your R/C car, boat, plane or train.</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt">I have been a licensed radio operator for years; please take my word on this.It is worth the few extra dollars to get a 72MHz radio if you’re in the air!</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt">I used 50MHz in the past (must be licensed) but I found I had to worry about RFI at 50MHz too because some unlicensed or un-educated people operated 6 meter radios out of band.Uggg.</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"></div> |
RE: wingspan?
Or 2.4GHz.
CGr. |
RE: wingspan?
okay thanks for the info on the 27mhz radios. i think i should switch my car to 2.4ghz too :D<div>
</div><div>MTK- what about the ember 2?</div> |
RE: wingspan?
ORIGINAL: electricrc68 ... what about the ember 2? Last fall we had an indoor climb-glide contest at Hartman Arena here in Wichita I was able to attain a best pure glide (from the time of switching the power off) of 31 seconds before it touched down (I was beat out by a modified Vapor that flew in the 40 second range - there's an article on this plane in the June 2011 issue of Flying Models, and the closest Ember 2 to me was at 25 seconds) and it by far beat out all the stock Vapors that attained around 20 seconds. On hot days the Ember 2 will also ride thermals quite nicely - I've done several 25 minute flights with only a minute of powered flight to get into the thermals. I limit my time due to the small battery aboard. Needless to say my Ember 2 probably has close to 200 flights on it while my Vapor may have around 50. Hogflyer |
RE: wingspan?
okay thanks. i guess i will get the ember 2. i heard it would fly nicely in a backyard too.
| All times are GMT -8. The time now is 03:09 AM. |
