RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   will this make a difference? (https://www.rcuniverse.com/forum/beginners-85/10647005-will-make-difference.html)
electricrc68 07-30-2011 03:53 PM
hey there guys. i was just wondering if putting a hobbyzone champ propeller on my ember 2 would make a difference in speed/motor temps?
jester_s1 07-30-2011 05:28 PM
RE: will this make a difference?
If it's a different prop, then yes it will. These little electric setups are fragile though, so if you put a prop on there that gives more speed then you'll definitely see lower flight times and will likely shorten the life of your motor and batteries.
electricrc68 07-30-2011 05:39 PM
okay thanks. i was just wondering in case the LHS doesn't have any propellers in stock. guess i will wait for the ember 2 props to come in stock then.
OkadaKeisuke 07-30-2011 07:02 PM
Did you ask if your LHS could order them in for you? If they can't, did you check online?
I found [link=http://www.amazon.com/Propeller-Spinner-Micro-Citabria-Ember/dp/B00120K1TC]this on amazon.[/link] Good luck hunting!
~Noah
electricrc68 07-30-2011 07:42 PM
thanks for the link. yeah i think they may have them back in stock on Monday when they get the landing gears back in stock too. so i will probably call them then and ask.
opjose 08-01-2011 08:51 AM
It is normally OK to replace an existing prop with one from a different manufacturer, provided that the prop is of the same size, pitch and type.
So if you purchase a slow flyer or GWS prop of the same diameter and pitch of the one you are missing, you should keep thing within the specs of your electronics.
However if you get something larger or of higher pitch, that will cause the new prop to draw more power from the ESC and motor, resulting in frying your components.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
