JR Crystal Question
1 Attachment(s)
This crystal is compatible with this receiver right? just wanna make sure http://cgi.ebay.com/JR-FM-Air-Receiv...item23125df0ed
RE: JR Crystal Question
That's a standard JR crystal for 72 mhz receivers. I don't see any reason why it shouldn't work.<div>
</div><div>Ken</div> |
thanks
The advertizing doesn't say if it is a single or dual conversion crystal ( it makes a huge difference! ), but the grey packaging is normally used by the Dual Conversion crystals, while the single conversion crystals have no gray packaging/holder.
Actually, JR dual conversion crystals are in a red package. JR single conversion are in grey. And most JR FM receivers are single conversion with the ABC&W thingie which filters out noise. There are only a couple of JR dual conversion receivers out there, and the one in the picture isn't one.
So yes, it looks like the correct crystal. (btw, this is why a "normal" JR crystal doesn't work in Futaba or Hitec gear, but I've seen plenty of guys interchange Hitec and Futaba crystals. Not a good idea, but it works most of the time since those are both straight forward dual conversion setups) for more info; http://www.jrradios.com/Search/Defau...ual+conversion http://www.jrradios.com/Search/Defau...chTerm=crystal http://www.jrradios.com/ServiceCenter/FAQ.aspx |
You're right... I had forgotten about the JR's being single conversion on all but some of the higher channel count RX's.
I still have a few JR 72mHz RX's with the Red Packaged crystals. |
iim glad i ordered the right one :) i dont have a problem still using 72 mhz stuff, i fly all my glow planes on 72 and havent had any problems in the past or present. They can be had pretty cheap.. i remember when i used to pay 129 for the 9ch 649 pcmS receivers.... now they can be had for peanuts
Crystal? What's that? :D sorry.. to much exposure to 2.4GHz... :eek::D
cgr
umm crystal, now isn't that used for fine wine drinking?? , or have i got the wrong crystal? |
:D Yeah, among other things..
| All times are GMT -8. The time now is 05:12 AM. |
