RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Escapade or stinger 2 (https://www.rcuniverse.com/forum/beginners-85/11046446-escapade-stinger-2-a.html)
benboy17 04-17-2012 05:20 PM
Wanna buy a new plane and it's between the escapade and the stinger 2 and I just can't decide. Which one should I get?
bigedmustafa 04-18-2012 07:44 AM
RE: Escapade or stinger 2
That is a very interesting choice to make, benboy17. They're both a great choice for a .40-size sport plane. I see a lot of Escapades out at the flying field, but not very many Stingers. I might opt for the Stinger myself, if only to have the less common of the two.
I honestly can't imagine you'd be unhappy with either choice. Good luck and good shopping!
Lone Star Charles 04-18-2012 10:55 AM
Suggest that you do a search for both airplanes here on RCU.  You will probably get a lot of comments about both planes.  Review what other owners have said about each airplane and then you can make an informed decision.  My son had an Escapade, it few well; however, elevator flutter was a big problem and the canopy had to be modified to get it to stay on - all those issues are addressed in other posts on this site.
benboy17 04-18-2012 12:40 PM
Yeah i did that lone star and Im still torn between the two. You know like a woman just can't make up my mind!!!
CGRetired 04-18-2012 02:01 PM
Look things over with both planes, for instance, look at the wing arrangement. The Stinger is a mid-fuselage wing mount where the Escapade is a low-wing mount, mounting to the bottom of the fuselage. That makes for a difference in handing and control.
Look over the wing span and wing loading. The Escapade has a 24 - 26 oz/sq foot where the Stinger is 20 - 22 oz/sq foot.
All this sort of stuff makes a difference on how it will perform, stall tendencies, and so on.
If none of this makes a difference to you, then what ever looks good to you is the one to get. Hey, get them both!!! Do your own compare and review!!!! [X(] Now there's a plan!! ;) :D
CGr
benboy17 04-18-2012 05:28 PM
Sounds like a plan CG!!! Can you convince my wife of that!!!
CGRetired 04-19-2012 02:38 AM
:D :D
VetteV12 04-22-2012 10:34 AM
I had an Escapade and it flew very well untill the gear let go and it did it's final and last no gear belly landing. The gear and canopy are my only complaints about it. The gear broke loose often, however I land on some rough blacktop. For the canopy I ghetto rigged it with rubber bands to get it to stay on. With the higher wing loading I also had to land with some speed or it would drop a wing.
Just bought a Stinger II a couple weeks ago (replacing the Escapade) and I'm almost done putting it together but so far it's been very easy to assemble. I'm using HiTec 485HB servos and a rebuilt Evolution .46 with a pitts muffler. I should have it in the air next weekend and I'll let you know how it performs. But from how it looks and the wing loading, I think it will a very nice flyer.<br type="_moz"/>
oldtyme 04-22-2012 11:29 AM
I have had two Escapades. The first one I lost due to a dumb assembly thing I did........but I flew it 8 months before then. I now have my second Escapade and love it. I took the gear off once but have since re-inforced the mounting block and that seems to have solved the problem. Many people have the same problem with the U-Can-Do. As far as the canopy, I don't know what the problem is unless people don't read the instructions and put a small amount of foam in the front between the dowels. Evidently, Great Planes became aware of the problem and included a fix in the assembly instructions. Great plane! I sell a lot of them for Great Planes out at our field. Just yesterday after a flight, a guy commented that he was going home to buy one.............:D
landeck 04-23-2012 06:33 AM
I have had an Escapade for the last four years. I have never had the gear come off or any problems with the canopy. It is a great flying plane with a Magnum .46 XLS engine.
Bruce
VetteV12 04-28-2012 08:42 AM
Just got back from flying the new Stinger II. All I can say is WOW! This thing freakin moves! I have an 11x6 on it and it's fast. The engine doesn't have enuf power to do vertical very well but it still powers it nicely. The ending weight ended up being 5.46lbs. I set my CG alittle nose heavy because I didn't want to add any more weight to it. But the CG line only moved 1/16" from factory recommended. It flies great and will do anything an acro is made to do. Snap rolls are incredible, knife edges are beautiful, ect... I think alittle more power would give it that sweet spot, like a 12x6 spinning at the same RPM I am now.
Hope this helps you make a decision.
benboy17 04-30-2012 11:28 AM
Thanks Vette
maukaonyx 04-30-2012 11:38 AM
Depends on what you have flown, what your experience is. I have the Stinger 2 and it is hot, but I do have a YS63 on it. I have seen several Escapades at my field. My personal estimation is that the Escapade is less a handful than the Stinger 2. If you have flown some low wing already, then the Stinger 2 will be lots of fun and good step up. If you are just embarking on low wing, then the Escapade might be a better step. Just my 2 cents! Good luck on your selection! Jon
vidasj 05-07-2012 04:21 AM
I have had several Escapade 40's, and one Escapade 60.  They are easy to fly, but the 40 size lands somewhat hot.  For around $100/ARF you can't go wrong, just be sure you're confident flying a trainer first.
-rwebb- 05-23-2012 08:07 PM
Just maidened my Stinger II last weekend. My second plane and my trainer was an Avistar. Love it. Have a saito 72 in it. Couldn't be happier.
