RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   tuned up (https://www.rcuniverse.com/forum/beginners-85/1129461-tuned-up.html)
madmanmikie 09-11-2003 03:35 PM
tuned up
hi, I have a superstar 40 with a os fp max .40 would it be benificial to put a tune pipe onboard rather than to run the stock muffler , I was told it would give more power, and also run quiter, would like to hear any responses to this question thank you[sm=idea.gif]
Montague 09-11-2003 05:26 PM
RE: tuned up
It wouldn't be worth the money on a trainer. You'll get more performance increase by just playing around with props to find the one that works best.
A tuned pipe will increase RPM, but only at full throttle. It also makes the engine's throttle response very non-linear, the engine will suddenly increase RPM as it comes on the pipe.
The FP engines aren't timed to really take advantage of a pipe either, so the RPM increase won't be huge.
The biggest advantage you'll notice is that with a full length pipe that will likely extend past the wing, your plane will stay a lot cleaner on an average flying day.
madmanmikie 09-11-2003 05:48 PM
RE: tuned up
Thank you Kirk for your advise, I think I'll take to heart what you have said and save the money and use it towards my next plane
