RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Needle Extension OS-46FX (https://www.rcuniverse.com/forum/beginners-85/1133921-needle-extension-os-46fx.html)
chicane 09-13-2003 09:56 AM
G'day guy's
I've just got myself a seagull PC-9. It has an inverted motor under the cowl.
How do you make an extension to the main needle valve so it will extend beyond the cowl? The engine is an OS 46FX.
Also, do I need an onboard glow driver for the inverted engine to idle?
CCRC1 09-13-2003 10:49 AM
RE: Needle Extension OS-46FX
Chicane, there should be a small hole in the end of your needle and a set screw on the the side. This is for an extension. Insert a piece of music wire into the hole and lock it into place with the set screw. Bend or loop the the end so you can adjust the needle by hand.
sigrun 09-13-2003 04:57 PM
No.
Generally that's more of a four stroke problem and issue. The only differential issue with running a two stroke sport engine such as the OS 46FX inverted is an increased ease of flooding the plug on refueling or priming and subsequently incurring difficulty starting or worst case, hydraulic locking.
chicane 09-13-2003 11:37 PM
Eexcell-ent !!
Thanks guy's. I was wondering about that grub screw.
Dsegal 09-14-2003 08:24 AM
In addition to using music wire, you can make an extension from those little hex wrenches that come with wheel collar sets. Cut to length and be sure to put some thread-locker on the grub screw.
David_Moen 09-14-2003 11:09 PM
I run an inverted 46FX on my ultra Sport 40+. After al the bad thengs I heard abot inverted 2-strokes, I was pleasantly suprised with the performance of mine. No trouble at all!
spooner 09-15-2003 06:21 PM
hi chicane..i had the same plane and and engine all i did was i got a short glow stick... i wish i still had her....lost her do to a messed up RX crystal....we use a scrap piece of push rod for the needle extension.
