OS Max 60 SR HELP!!
Had a mishap and the front drive washer and the prop shaft are goobered up. The front bearing is a standard r6 so the drive washer is @10mm and has a collect to wedge. I cannot fan a washer to replace this one. can i use another one? also the prop shaft screws into the cam and it is a 1/4 shaft with 28 thread count. any ideas where to get. Will buy from one of you guys via paypal if you have the parts i need!!
RE: OS Max 60 SR HELP!!
Try the glow engine thread for this, I guess you want a US based supplier.
| All times are GMT -8. The time now is 03:58 AM. |
