RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Monocote Question !!!!!!!!! (https://www.rcuniverse.com/forum/beginners-85/1143456-monocote-question.html)
DragonHeart 09-17-2003 03:50 PM
Hi,
Hope someone can give me some insight to this, i have a GP SuperSportster 40 but every time i fly the covering seems to wrikle bad, and needs ironing flat everytime i come home.
Is it me being fussy or is this stuff not much use ?
Can anyone recommend another way to cure this prob ?
Also is a heat gun better than an iron for this covering ?
Thx in advance for your time..............
PaPa-NeGeorgeo 09-17-2003 04:13 PM
RE: Monocote Question !!!!!!!!!
Hey DragonHeart,
Firstly you wanna check the edges and make sure its all locked down and air tight, then you can take a heat gun and just go over all the monokote. Remember with monokote you need alot of heat so dont be too hsaty with the gun keep it there for a bit (of course not too long to burn a hole through). Eventually the monokote will start to were out but it shouldnt be after every flight.
Hope this helps,
Papa
DBCherry 09-17-2003 08:18 PM
Where is it wrinkling, all over or just the wings? If it's just the wings I'd be concerned that there's a structural problem causing the covering to wrinkle. If it's the fuselage as well, then buy a heat gun and shrink it really well.
Dennis-
