Field accesories
Break in accesories
I need help about the correct name for hold bars or holder stick, the sticks that you put in the grass for hold the airplane while run up and break in process? thanks a lot! <br type="_moz" /> |
RE: Field accesories
I use a rope tied to the shade posts for starting alone. Do your break-in in the air. Less load on the motor, and the motor won't know the difference.
Thanks!!
| All times are GMT -8. The time now is 11:39 PM. |
