RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Prop size (https://www.rcuniverse.com/forum/beginners-85/11469652-prop-size.html)
chopper man 04-05-2013 11:37 AM
Prop size
I am running a 3 bladed prop on a magnum 70 FS and was thinking that if I went to a 2 bladed prop I would get a little bit better performance. I have that engine on my Daco Red. Any suggestions as to what size prop would be best?
Gene
tailskid 04-05-2013 01:34 PM
RE: Prop size
Go down one in pitch and go up one is diameter......at least that is the general rule.
carrellh 04-05-2013 05:32 PM
RE: Prop size
My 70s work well with 13x6.
nitro wing 04-05-2013 07:05 PM
RE: Prop size
on a racer he may want to drop to 12x8
Charlie P. 04-06-2013 06:57 PM
RE: Prop size
I run 13 x 7 on my OS 70 FSII.
chopper man 04-07-2013 12:43 PM
RE: Prop size
Thanks for the help. One more question. If it says break in an .52fs with a 12x5 would it hurt anything by using a 12x6?
Thanks.
Gene
tailskid 04-07-2013 01:02 PM
RE: Prop size
Noope....just don't break it in too long - they break in much better in the air after a couple tanks of fuel.
JohnBuckner 04-07-2013 03:38 PM
RE: Prop size
ORIGINAL: chopper man
Thanks.
Gene
I prefer to use a light prop load for break-in as apparently your manufacturer has. This regardless of the way you choose to beak-in whether it be on a stand, the airplane or perhaps a combination of the two. While no you may not "hurt" anything using the heavier prop load you just may find yourself with a better engine by using the recommended break-in prop.
You never said what airplane but now is the time to start building your "propwall" Every flyer of fixed wing aircraft needs a prop selection and besides whatever that ship is you may just find out the 12x5 could work better, only you will be able to ultimately answer that by actual trial.
John
