RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   first flight today! (https://www.rcuniverse.com/forum/beginners-85/11557682-first-flight-today.html)
slider_buck 07-09-2013 04:00 PM
RE: first flight today!
bought the tower hobbies charger. doesnt have a discharge function but it will serve its purpose for now. i'll just set up a small motor to use as a discharge device.
slider_buck 07-09-2013 04:03 PM
ORIGINAL: Live Wire
This Guy has this 1 strung out:eek::D
and just how have i got it strung out? it sits exectly like it did when i got it new other then the low voltage beeper that i just now put on. the battery that i ordered is a hobbico battery which was far from the cheapest out there. the charger was the only thing i was looking at that was on the cheap side. i guess no matter what forum you get on there is always some guy who thinks he is so much better than everyone else just because he has been in it for a long time and spends a ton of money.
Live Wire 07-09-2013 04:41 PM
Its not how long you have been in the hobby or how much you spend it is how wisely you spend your time and money.
GOOD LUCK
Calvinman 07-10-2013 12:34 PM
Hi everyone, John I don't really think the TX battery has to be changed out, I used to fly 3 planes RX's dry and still have to leave the TX on for hours after I got home to cycle it down. Are the more modern TX's harder on batteries? I only have 8 or 9 flights on my FASST radio and it seems to have the same characteristics as my old super seven. Just my two cents worth.Calvi.
thepamster 07-10-2013 02:41 PM
Hey Calvin. I am sure JB will chime in shortly. I don't believe the new transmitters are harder on batteries but are more sophysticated and may draw slightly more current than the old ones. I think the old Super Seven came with 500ma pack and the new Fasst T7C is 600ma.
When the Super Seven was out most all microprocessors used a 5volt supply where now the standard is 3.3 with some less than that.
I don't believe a guy needs to buy a new transmitter battery unless he plans on his transmitter being on for more than 2 hours on that day. I call it a day after mine has been on for an hour or slightly more. Transmitters are low current devices. Servos are what draws higher currents.
Typically you don't get a larger battery for your plane for more flight times but rather for higher loads. i.e. more servos or larger servos. Not talking about electric airplanes with electric motors here, thats a different animal.
Still however with a nicad or nimh in the transmitter it should be charged the night before you go the field.
slider_buck 07-10-2013 03:13 PM
ORIGINAL: Calvinman
thats what im seeing also. everytime i have had it out the indicators on the tx have always stayed all the way up. now granted im not keeping mine in the air as long as you guys are. each one of my flights only last a few minutes and then i land. want to get as much experiance landing as i can right now.
Calvinman 07-10-2013 04:58 PM
For me, I just use my voltmeter with a resistor on it and call it a day when the voltage gets down to 4.9 under a good load, the think the resister I am using now draws more than 500 ma. I used to call it quites at 5 volts, but with a higher resistance.
And I agree, the most important thing is to cycle TX and RX down, then a full days charge before flying again. I found plans for a battery cycler online and built one, but I should get off my wallet and buy one with some features it would be nice to know how long the battery lasted before it cycled with out having to watch it.
Calvi
drube 07-10-2013 05:15 PM
Pick up one of these so you can test before every flight.
www.hangar-9.com/Products/Default.aspx
Calvinman 07-10-2013 05:34 PM
Nice Drube,
I do test before every flight, the one time I did not(forgot my meter at home) it cost me my scratch built HE 113. I flew the Second flight with the flaps down(huge two panel flaps) but was not quite smart enough to relize I should have the servo "straight arm" the control rod to reduce/eliminate the load on the servo, The third flight was a full throttle slow dive into the dirt while I tried bending the stick back on my radio :( I never did find the elevator servo :)
Calvi
drube 07-10-2013 05:49 PM
Sorry to hear about your HE 113! I learned the hard way myself. Lost my first build (GP Corsair) because I took a chance and thought that my batteries had enough charge. Now I always check.
Calvinman 07-10-2013 05:53 PM
Nice plane, one of my dream builds, how did she fly, did you have use flaps on it, the flaps on the corsair are the same as on the HE 113.
Calvi
rcjetflyer0718-RCU 07-11-2013 07:20 PM
Talking about transmitter batteries for Futaba and JR has no bearing on Airtronics transmitter batteries; read the reviews on the airtronics. The chief complaint is the short life of the transmitter batteries. The OP has an Airtronics radio, no meter just 4 color leds.
slider_buck 07-12-2013 02:44 PM
ORIGINAL: rcjetflyer0718-RCU
yep thats correct. so i shouldnt trust the led's then? the only time i have seen it come down 1 bar was when i was testing the strength of the batteries in the house and had it on for about an hour.
thepamster 07-12-2013 09:16 PM
I would discharge the batteries down and do a range check for just curiosity and see how far down the leds would go before I loose range. Maybe discharge down one led at a time.
slider_buck 07-18-2013 04:24 PM
ORIGINAL: thepamster
well i did this today and i was able to drain the battery clear down to the last led indicator while still controlling the servos. i was about 300 feet away. the receiver battery was still at 5.1 volts after all that. took about 3 hours to get the transmitter drained down. pretty happy with that.
slider_buck 07-21-2013 12:11 PM
well i have had 5 flights now since the new receiver battery and charger. i couldnt be happier. the first time out i did 3 flights and when i checked the receiver battery it was at 5.5 volts. the other 2 times out i kept it in the air longer and the battery was at 5.3 volts. both times the transmitter battery never came off of full charge. starting to do some 180 flips now. after a few more times out might be investing in a 3d plane. thanks for all the advice guys.
thepamster 07-21-2013 08:20 PM
Congrats on the success with the new equipment. Good job on the range testing. It always feels good when you have confidence in the equipment you are using so you can focus on flying and having fun.
slider_buck 07-22-2013 08:20 AM
yes it does. already having problems with the hobico low voltage alert though. it started beeping like i had lost the plane. it has a 2 year warranty so i wrote them about it. i put 180 flip earlier but i really meant a loop. tried to do a barrel roll but it just isnt responsive enough to spin real quick.
JohnBuckner 07-22-2013 01:03 PM
ORIGINAL: slider_buck
Most any trainer type will barrel roll very nicely however just using aileron is not going to do. You also have to add rudder with the roll and don,t forget to add momentarily a touch of down as you approach the inverted postion. Its at this inverted portion of the roll where most panic and stop rolling with the ailerons That's usually not a good idea as the normal result is a panic pull of up and a figure 9 into the ground. keep the pro roll aileron and rudder until the maneuver is completed.
John
slider_buck 07-22-2013 03:43 PM
ORIGINAL: JohnBuckner
John
thanks for the input. def going to give it another try next time out.
red head 07-22-2013 04:08 PM
Another little trick on doing a roll is to put the plane on about a 45 degree up line before you start the roll. That gives you a little more time to think about what you are doing until you get used to it. Another thing to remember is to make sure your plane is STRAIGHT before you start something. If you start crooked, chances are you will end up real crooked, after you do a few you will learn how to keep it straight . ENJOY !!! RED
drube 07-22-2013 04:13 PM
Gonna jump to a 3D plane next? Not sure if that would be a good 2nd plane.
thebest_102 07-22-2013 05:01 PM
It sounds like you were attempting an aileron roll vice a barrel roll. Aileron rolls stay nice and flat in a straight line as the aircraft rolls through. A barrel roll looks way different in that the aircraft looks more like its spiraling the attempt is to keep a 1 g load on the aircraft through the maneuver. Not sure how to measure it in RC but A barrel roll uses all the surfaces to make a more spiral looking roll while the aileron roll uses the surfaces to have the aircraft roll in a nice straight and flat line. I do aileron rolls in precision aerobatics. I do barrel rolls in warbirds.
thepamster 07-22-2013 05:59 PM
ORIGINAL: thebest_102
It sounds like you were attempting an aileron roll vice a barrel roll. Aileron rolls stay nice and flat in a straight line as the aircraft rolls through. A barrel roll looks way different in that the aircraft looks more like its spiraling the attempt is to keep a 1 g load on the aircraft through the maneuver. Not sure how to measure it in RC but A barrel roll uses all the surfaces to make a more spiral looking roll while the aileron roll uses the surfaces to have the aircraft roll in a nice straight and flat line. I do <span style="color: #ff0000">aileron rolls </span>in precision aerobatics. I do barrel rolls in warbirds.
Also known as an axial roll.
slider_buck 07-23-2013 11:12 AM
didnt realize there was a couple diff rolls. the axial roll is what i was trying. from what i have read i need to use elevator along with the ailerons to do that right? the barrel roll uses the rudder with ailerons.
