RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   glow plug for m-46 engine (https://www.rcuniverse.com/forum/beginners-85/11572749-glow-plug-m-46-engine.html)
slider_buck 07-17-2013 04:55 PM
i want to order some spare glow plugs but not sure which ones to get. it is for a megatech airstrike which has the ball bearing m-46 engine with an 11x5 prop. im running wildcat 15% fuel. what do you guys recommend? thanks
jester_s1 07-17-2013 07:02 PM
RE: glow plug for m-46 engine
OS #8. Always an OS #8.
Gray Beard 07-17-2013 07:23 PM
Like the jester I have never had a problem using the OS#8 in any .46 engine.
Hossfly 07-17-2013 07:50 PM
ORIGINAL: jester_s1
AW GEE Jester! Here is one we kind of disagree with. In my not-so-humble opinion, The O.S. #8 is the most highly over-rated glow plug that has ever been levied on the RC pilots. OH SURE it is fine and does well but the over-rating comes from the fact that Great "Pains" and its sub-chapter "Tower" needs such a reputation just to maintain that highly over-rated price. :eek:
Now for anyone wanting very good performance at a much lesser cost, simply try the McCoy 59, which is an excellent choice for most flying. If running a fuel or system using the OLDer single bypass engines, then the MC-50-Idle Bar will do the job. The idle bar will last a bit longer when using nitro of 25% or more. Back in the olden days when I did pylon racing, '70s and 50-70% nitro, these cold plugs could get 2 flights. Other plugs were lucky to get one into the last lap. In reality I use the MC-50 most of the time in all my flying.
Hey slider_buck, best wishes to you. Almost any current glow plug will do well in sport engines. Some quit on the first flight and some never quit. Jester is usually 101% right on all his help, so I just have to spoof him a tad bit. :D
jester_s1 07-18-2013 05:30 AM
Much appreciation on the spoofing Horace. You're right, there are cheaper plugs out there that also work fine. So if saving $2 over the course of a year or two of running an engine is important to the newbie pilot, it's possible to do so.
slider_buck 07-18-2013 04:36 PM
thanks guys. i ordered 3 #8's.
