first prop bite!
2 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=1926316http://www.rcuniverse.com/forum/atta...mentid=1926317 reaching for a flathead screwdriver lost my balance !
Yikes!
What's the prognosis? |
What size engine? Idle speed or what?
cut tendon fracture in knuckle had pin and screw put in yesterday in surgery.
Ouch! I feel your pain. I badly cut my thumb 12 years ago. Not quite that bad. I have fifteen stitches and nicked the end of the bone. Good luck to you.
at a high idle speed
Hope you recover quickly.
Thanks for posting the pic...
helps remind me to FOCUS on what I'm doing. heal quick... pop |
been aweek since had the surgery flying again amazing what surgeons can do to get you back on your thumbs ;)
Hi izzy-israel-73
That is a horrible cut. We all seem to have to go thru the same pain and experience. I see people reach over the engine to remove the glow plug driver while the engine is running. I always walk around the plane and remove it from the back of the plane. Also, we have 7 Engine Starting Safety Stands at our field. That is a tremendous safety feature. |
This is a good reminder for all that fly. Be careful what you are doing around spinning props. Hope you get better soon, Dave
Choreograph all your movements around the engine to a set routine that you never deviate from ahead of time.
Never be in a hurry to do anything. Have a well rehearsed engine kill worked out and treat every engine like it will fire up at WOT every time. |
Ouch. I did one similar when I was 16 but it cut my finger the other way, down the middle, straight through the nail and took the end of the bone off. Also had a few other lacerations to other fingers. That was at WOT though. Its a nasty reminder of what they can do to you.
You're not alone I got 3 fingers on my right hand back in 07. Mine was through the bone on 2 fingers.
heal quickly |
[QUOTE=combatpigg;11632525.
Never be in a hurry to do anything. [/QUOTE] +1 good to hear it's healing well ! cheers, V. |
could you please post a picture can show the boy's down my club ?
Yes I need to get myself a table or bench as I have a bad back...Never had so much trouble with this 55 ax !
Thanx Guy's , the wound is healing nicely movement in thumb and feeling so all is good so far...
If it doesn't kill you it just makes you stronger... ;)
V. |
Yes you're right there I had everything arse about face not how I usually set up long story but I learnt the hard way !
Hi izzy-israel-73
I almost missed you request for more information. The plans for the Engine Starting Safety Stand we use can be downloaded free from our club web-side at www.wilsonrc.org/news.php. Click on Downloads and look for the name Engine Starting Safety Stand. I'll try to post a photo also. I just tried to post the photo but I cannot figure our how to do it with this new system. I hope someone will see this and help me with more information. I'm only 77 years old and still alive. |
Hi again izzy-israel-73
I just remembered something else. Some people will resist using the Engine Starting Safety Stands since they never had a need for them before, and have always started the plane on the ground. I did that for years also. Ask them if they ever started a .60 engine while holding the plane on the ground with, one hand, and did not notice that the throttle was wide open? Sure this is stupid, but it has happened to me at least twice that I can remember. In my case, I had the plane on one of our Engine Starting Safety Stand. I built, paid for, and donated to our club, the first stand, after redesigning it. |
G'day Villa, :)
yes I have seen a Utube video with a accident just as what said about ! We do have a set rule that all planes have to be pegged while starting them 2 pickets standing in front of you're leading edge of your wing! |
Hi Villa check this out, sent from one of the guys off one of my other threads http://www.meroke.com/sbbuildinginstructions.htm
G'day Villa on my other thread, prop bite 1 week later there's a link from daveopam of a designee of a safty bench for rc need a few at our club would be great for guy's like me with a bad back!
Hi 1zzy-isreal-73
Our club built 6-7 of the Meroke stands you mentioned. We had to repair them after a few years, and again after a few more years. I then redesigned the stands to eliminate weaknesses I had noted. Our club built 7 of the new stands. These new stands are now about 6 years old and have required zero rework. We built them with wheels under the vertical posts. Those are the Engine Starting Safety Stands on our club website I referred to. Make your own choice. |
3 Attachment(s)
Here is another version of a starter stand, or bench.
Like the Meroke style benches, they can be made in a large and small version. I had some issues with the Meroke style benches, mostly a lack of space on the top and a tipping problem if they were not made from treated lumber. |
Those engine starting benches are absolutely great. Not only are they so much safer than getting down on the ground and starting an engine, they keep the aches and pains associated with getting doiwn on the gound out of it. When I was 40, getting down on the ground and then getting up was no problem. At 60, it started being more difficult. At 75, I love the starting benches.
I have requested to the club that they would be great for the club but I haven't seen anything been done was told they will just get vandalised !
izzy,
That is an excuse that I've never heard before. Our club has about $1,000 worth of damage a year, but so far it has been limited to our storage sheds, snacks and drinks. It would be nice if the vandals, or taggers, would paint our benches like they do everything else that isn't moving at a high rate of speed. You could build one and see what happens, the cost is about $50 in US dollars. If it would prevent just one "body part in the prop incident" it would be worth it. I know that when I fly from fields that don't have any benches or tables, I get a little nervous because at my age it is hard to keep my balance when getting up and down from the ground. My fear is that I will fall on my plane and cause some real damage to my body with the prop. |
Hi izzy
I built, and donated to our club, the first Engine Starting Safety Stand to my new design. We have had stands at our club for about 10 years and have never had a problem with anyone stealing them. I think the cost of most of our stands were donated by individual members. One of our members enjoys building them. To Jolley Popper I mention that I am 78 now and fly 2-3 times every week if the weather permits. I'm happy not to kneel or bend over. |
Villa,
Do you have any pictures of your design? |
There's two types of rc plane enthusiasts out there, those who've been prop bitten, and those who are going to be prop bitten.
Dam Izzy - that did NOT look good, snapped tendons are a right royal pain in the you know what. Snapped the top tendon at the last knuckle on my right middle finger a few years back de-icing my wife's car, not painful but 3 months of 'mild nuisance' adds up ! (though not 'quite' as bad as when I snapped my left quad tendon - 24 staples to close the surgery point and permanent sutures in my knee that they used to tie that tendon back to my knee - it was 10 months before I finished physo on that occasion!)
Not good kiwibob!My thumb is only 50% id say don't think it will get any better then what it is pisses me off as it has effected me with my flying with left rudder and throttling !!!
oh I forgot and would be very time consuming to build lol bloody 3/4 of the club members are retired I am sure we could plane a day to go over plans and make a bench ! Well all I can do is put it to them at the next monthly meeting and see how I go mayby get a voted in !
Originally Posted by izzy-israel-73
(Post 11791039)
Sorry to hear that your thumb is not healed up to 100%. I had a pistol blow up in my hand earlier this month, the barrel split in two and parts went in all directions and I got quite a few cuts on my hand. My thumb took quite a beating and I have lost some of the feeling in the tip; my pitch and roll may suffer when I try to fly again. Our club has the same problem with age. I'm sure that most of the old retrired guys do most of the work in your club like they do in ours. I'm 71, don't bend well and have back problems, and have built one of the benches in Tennessee while I was there on a trip. They are pretty easy to build. |
(Post 11791033)
So here is hoping you'll come out as good!! |
I just think we could make the club work better if some of the older members didn't mind some changes!
| All times are GMT -8. The time now is 08:57 PM. |
