RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   installed cowl on plane for the first time!!! (https://www.rcuniverse.com/forum/beginners-85/11594768-installed-cowl-plane-first-time.html)
izzy-israel-73 02-14-2014 11:51 PM
Installed the cowl on my plane , plane had been trimmed out earlier took off next minute plane started a steep climb didn't understand why and still don't has any body had this happen to them before?
jetmech05 02-15-2014 05:29 AM
Didn't something shift aft?
Other than that you're more aerodynamic with the cowl on. Reset trim at half throttle or so and see what happens
flyinwalenda 02-15-2014 05:44 AM
Who knows what kind of plane you have but I don't know of any where an installed cowl would push the nose up that much. Maybe a slight difference but nothing dramatic. I would check the elevator surfaces and linkages and as mentioned the CG.
speedracerntrixie 02-15-2014 08:25 AM
You would be amazed what can cause a trim change. Last race season I lost a stripe of covering off the bottom of my wing. This left a bare wood area about 7 inches long and 3 inches wide. The airplane took half of my available up trim. After the heat I covered the section with packing tape. Next heat I had to take the up trim out. A cowl will certainly cause a difference in trim. Then again the OP doesn't even state what airplane let alone post a picture with cowl off.
