Help with new engine
Hi
I have bought a new MDS .58 nitro engine but it did not come with any glow plugs. In the instruction manual it says to use Hanger 9'S Han 3005 economy or Han 3000 performance plugs. But I can not find any of these plugs. What other plugs can I use Cheers Len |
You might try one of these http://www.horizonhobby.com/products...t-plug-HAN3001
Wouldn't an OS plug from your LHS work
Any brand of plug that's long reach (nearly all of them) and between a medium and hot heat range will be fine.
Enya no 3 plug works well in that engine.
5% nitro fuel if you can find it. 10% max. In my experience they take a while to run in and develop a reliable idle. Say an hour. This engine has sat around for a while so check the O ring in the needle replace if suspect.. From memory an OS one fits. |
I used the OS #8 in all of mine. It's a high compression engine and designed for zero or low nitro fuel. I used 15% but they ran better with 5%. Where on earth did you find a new one?? H-9 only imported them for a short time due to problems with them. Russians revenge!!;)
Thanks guys at least I have got something to go on now.
| All times are GMT -8. The time now is 12:17 PM. |
