RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Servo not centering issue (https://www.rcuniverse.com/forum/beginners-85/11605243-servo-not-centering-issue.html)
c130FE 10-10-2014 04:19 PM
I have an issue with the rudder servo on a plane I just purchased that has me scratching my head, need some help.
If I take the rudder stick and deflect it right or left a little, then let go of stick, the rudder returns to center as expected. If I take the stick and fully deflect the stick to left, and then let go of stick, the rudder returns to a point that is about 20 degrees to the right center. Then, if deflect the stick ful right and let go, the stick returns to dead center. Power is coming from a fully charged LiFe battery.
All other servos act normally.
Tried 3 different rudder servos this afternoon, same result
Replaced servo cable between receiver and tail of plane where servo connects to it, same result.
:confused:
speedracerntrixie 10-10-2014 04:59 PM
You have a binding pushrod, hinges or something else in the system. Disconnect the linkage from the servo and move by hand to feel the bind.
j.duncker 10-10-2014 05:33 PM
Make sure the servo mount is not loose and moving a little.
BarracudaHockey 10-10-2014 06:50 PM
Disconnect the pushrod at the servo and see if it does it. Though not likely, you could have a bad stick pot in the radio.
Bozarth 10-10-2014 09:02 PM
And one of the most obvious...a cheap servo. Don't chase your tail too long on the issue.
Kurt
