How do you do it?
How do you hook up retracts for the main gear and the nose wheel? Do you make a Y-Harness using 3 leads instead of 2? Not sure I have enough soldering skills to make a 3 lead harness.
Its a good time to start soldering and a simple three way Y cord is very easy to do. You can avoid soldering and can do it by using 'two' two way Y cords but you will end up with an extra lead to stuff into the airplane.
John |
Can you use an open slot on the Rx and mix that channel with the retract channel? Sort of like 2 aileron servos?
Buzz. |
| All times are GMT -8. The time now is 09:09 PM. |
