RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   plane engine (https://www.rcuniverse.com/forum/beginners-85/11612132-plane-engine.html)
oldoak 01-17-2015 02:54 PM
plane engine
what size plane can I use evolution 120 engine?
jetmech05 01-17-2015 05:31 PM
If you're a true beginner bigger than your ready for. A 4 Star 120 or a tiger 120 if you can find one.
If you got some flight time under your belt then those two airplanes will make a good choice
flyinwalenda 01-17-2015 05:39 PM
Almost any 120 size plane. Question is, what planes have you been flying up to this point?
Fs one 01-26-2015 05:11 PM
Question is what kind or type of plane do you want to fly?
Gray Beard 01-27-2015 02:51 PM
The engine works in any 120 size plane so it's up to you.
JollyPopper 01-27-2015 04:47 PM
I assume you are new or relatively new to RC and the answer to your question is so obvious it has us confused. A .40 size engine works well on a 40 size airplane, a .60 size engine works best on a 60 size plane and a 1.20 size engine is recommended for a 120 size airplane. That is not intended to be a smart ass answer, but it sounds like it its.
Gray Beard 01-27-2015 06:59 PM
Of course sometimes a 120 size engine works great on a 60 size plane.;)
52larry52 01-27-2015 09:33 PM
Let's see.....no reply from the O.P. after 7 days, 2 posts per his bio, and as pointed out an obvious answer to his question. Have we been "trolled"? Just wondering !
