RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   PS Maxi 30cc Engine Fuel (https://www.rcuniverse.com/forum/beginners-85/11612440-ps-maxi-30cc-engine-fuel.html)
mrcoolpop 01-24-2015 08:14 PM
Hello,
Need some assistant in getting fuel for this plane. In some threads it says that you can use 0% nitro & 5% oil Cool Power in and regular 10% RC fuel. So confuse, which is correct.
Gray Beard 01-25-2015 07:59 PM
Not familiar with the engine but high compression engines like the Moki run better on FAI fuel, that's just methanol alcohol with 20% castor oil. Most shops stock 5% nitro and they also run well with that. 10% nitro they may or may not like that much nitro. A lot of the engines made in Europe were designed to run with just FAI fuel because of the cost of nitro there. MDS engines from Russia were a good example. Higher nitro isn't going to hurt it but it may not run well with it? All you can do is try it.
I had a number of the MDS engines, only one ran well with my normal 15% nitro and the rest I either mixed up my own FAI fuel or used 5%.
mrcoolpop 01-27-2015 06:11 PM
Grey Beard,
I went by my buddy and go the FAI fuel but it has 20% oil? Is it possible for me to use this in the OPS Maxi 30cc. Can't find any methanol or 10% nitro anywhere.
speedracerntrixie 01-27-2015 06:32 PM
The Maxi has needle bearings at both ends of the connecting rod. This means it will run well on 5% oil. 20% oil is way too much and I would not suggest an all castor fuel in anything. The best setup you can do is straight methonol with 5% Klotz Thechniplate. Methonol should be easy to find just about anywhere and the Klotz can be ordered online. I would also suggest an OS F glow plug. The other option would be to have it converted to gasoline. All that is required is an ignition system. Do a google search on converting the Maxi and a good article will come up.
Gray Beard 01-27-2015 06:32 PM
OOPS, as Shawn pointed out, needle bearings don't care for a lot of castor oil. I have never seen the engine and thought it was a normal ball bearing engine.When I was mixing my own fuel I was able to get the alcohol and nitro from a local speed shop and I get my Castor oil from SIG. My local Hobby People stocks 5% fuel in gallon plastic jugs. I was also buying the Klotz oil from Tower.
