Beginner radio Rx problem
Anyway, here is my dilemma. I have to center my aileron's electronically before I can mount the hardware. I'm running a Spektrum Dx7s and a six channel Sepktrum receiver (Ar6210) both dsmx. I have bound the receiver to the radio. When I shut the receiver and radio down and plugged in the servos and turned everything back on I hear the servos on but I have no control of them through the radio. What am I doing wrong? I have a live 6.6v receiver battery.
Moderators this is a double post. Please del. the first post as I am not sure where I posted. |
Stupid question are you sure you have the servos plugged into the correct channel the correct way?
I think you should re-bind.
First, when linking (powering up a system that is already bound) the system move the transmitter a few feet away from the receiver
second, if the receiver uses one, make sure you have the satellite plugged in and bound. Last, make sure the servo is plugged in the correct orientation. |
| All times are GMT -8. The time now is 09:38 PM. |
