powerbox systems
hey guys
when does it become necessary to use a powerbox system? and also what are the main reasons to use one? mainly to be able to use 2 or more servos on one channel? how about amp drainage via receiver to servos if one uses HV servos? |
120CC plus airframes then maybe.
Most computer radios these days will do multi servos on one channel and HV servos without a Powerbox |
Not sure about a power box. But a smart fly will act as a power filter. In other words it will clean up and regulate the voltage. Allows 5V to the receiver and up to 6.5V to the servos. It's a batt share. Servo match. And optic kill.
I run one on my 100CC Edge and another on my 170CC Sukhoi |
ok sounds like powerboxes are more about being fancy these days then :D
There's applications where they are either needed or will make life a lot easier but you're getting into big and complicated stuff before you reach that point.
| All times are GMT -8. The time now is 12:31 PM. |
