Reversed control surfaces
Hello all, I rescently got the avistar elite. I fid some work on it, and now I realized that everything but the ailerons are reversed on my dx6i, but EVERYTHING is proper on the dx8. My dx6i reverse settings are all in normal, not sure about the dx8 since I dont know how to get to the reverse on the dx8. Is there a reverse all on the dx6i, or do I need to reverse them all seperate? Also, why would it work on the dx8? (When I move the aileron stick tight the right aeileron moves up correct?)
They need to be adjusted separately
They might be opposite between different transmitters, nothing to worry about |
If your control surfaces are reversed then go in the radio and reverse the surfaces that are wrong. It makes no difference what the radio says.
Agreed, reverse the controls that need to be reversed. Do not worry about the radio screen for reverse or normal. You can use the screen for almost everything else, such as dual rates, or end points. Good Luck, Dave
| All times are GMT -8. The time now is 11:47 AM. |
