RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Lazy Bee (https://www.rcuniverse.com/forum/beginners-85/11638403-lazy-bee.html)
Faster Wind 04-22-2017 11:25 AM
Lazy Bee
15 Attachment(s)
It all started last year.
Accidentally met on the Belarusian forum topic about this model.
And fell in love at first sight.
Toy design, simplicity of design, the most stable aerodynamic scheme - my dream of which I did not know before! :)
And of course I wanted to build this unit.
All the necessary equipment was available in the mines - the motor, the tank, the servos, the accessories.
All the constructions of this model on the Internet, which were found on different forums, usually manual,
from the rack on paper drawings (in our studio it's called retro on .. but: D)
In this project, I tried to translate the simplicity of assembly, with minimal manual Processing.
I want to collect it quickly, because Cessna will not take off soon, and the season begins, the warm days were already, the fields will soon dry out :)
The wing span is 1100 mm.
Engine Tander Tiger GP-25.
Take-off weight 1000 gr.
The details are made of 3mm birch plywood.
Liners are pine reiki. Sheath of balsa 1,5mm.
[ATTACH]2211079[/IMG]
[ATTACH]2211080[/IMG]
[ATTACH]2211081[/IMG]
Weight of plywood parts.
[ATTACH]2211082[/IMG]
The beginning of the gluing.
[ATTACH]2211083[/IMG]
[ATTACH]2211084[/IMG]
[ATTACH]2211085[/IMG]
[ATTACH]2211086[/IMG]
[ATTACH]2211087[/IMG]
[ATTACH]2211088[/IMG]
[ATTACH]2211089[/IMG]
[ATTACH]2211090[/IMG]
[ATTACH]2211091[/IMG]
[ATTACH]2211092[/IMG]
[ATTACH]2211093[/IMG]
Faster Wind 04-23-2017 05:47 AM
14 Attachment(s)
Preliminary gluing is over, now i can assemble the fuselage.
[ATTACH]2211117[/IMG]
[ATTACH]2211118[/IMG]
[ATTACH]2211120[/IMG]
Loop for rudder axis.
[ATTACH]2211122[/IMG]
[ATTACH]2211124[/IMG]
The gluing takes place on a flat table, the fuselage is flat at the bottom.
[ATTACH]2211126[/IMG]
From above also flat only there is a ledge of a loop in a tail, it is necessary to hang from an edge of a table.
[ATTACH]2211128[/IMG]
The nasal part will be clad with balsa 1,5mm.
[ATTACH]2211130[/IMG]
Accidentally broke the part, glued on the glue, nothing terrible.
[ATTACH]2211132[/IMG]
[ATTACH]2211134[/IMG]
The last frame of the fuselage.
[ATTACH]2211136[/IMG]
Pressed the goods to dry out evenly.
[ATTACH]2211139[/IMG]
[ATTACH]2211140[/IMG]
Hinges for the rudder axis direction.
[ATTACH]2211142[/IMG]
del
Faster Wind 04-23-2017 05:54 AM
What's happening? At me all hangs up, then are two my posts.
I did not specifically press the keys and waited for the page to reboot itself.
I also did a few topics about the bee.
jester_s1 04-23-2017 08:22 AM
The forum just upgraded to a new software package, so it must be a glitch. I deleted the duplicate threads. Your built looks good. I'm anxious to see how it turns out.
Was this a kit or did you have it laser cut yourself?
Faster Wind 04-24-2017 06:29 AM
25 Attachment(s)
Thank you Jester, now it is clear what's the matter.
Assemblage of the wing.
The wall of the spar consists of 3 parts.
[ATTACH]2211505[/IMG]
[ATTACH]2211506[/IMG]
Split the front and rear edges at an angle.
For this, the ends of the edges are machined to the desired angle.
[ATTACH]2211508[/IMG]
[ATTACH]2211510[/IMG]
Back edges for endings.
[ATTACH]2211512[/IMG]
[ATTACH]2211514[/IMG]
Front edges behind the endings.
[ATTACH]2211516[/IMG]
[ATTACH]2211518[/IMG]
The edge for the endings consists of 3 parts.
[ATTACH]2211520[/IMG]
[ATTACH]2211522[/IMG]
[ATTACH]2211524[/IMG]
[ATTACH]2211526[/IMG]
[ATTACH]2211528[/IMG]
The main spar, pine rake 7X3 mm.
[ATTACH]2211530[/IMG]
[ATTACH]2211532[/IMG]
Before inserting the spar, the ribs are put on the side member wall.
[ATTACH]2211534[/IMG]
[ATTACH]2211536[/IMG]
[ATTACH]2211538[/IMG]
At first the central part of the wing is collected, so I did not put on the ribs for the endings.
[ATTACH]2211540[/IMG]
[ATTACH]2211542[/IMG]
Lower spar with allowance for processing.
[ATTACH]2211544[/IMG]
[ATTACH]2211546[/IMG]
Also on the bottom plane are glued three more slats 2,5X3, 5 mm.
[ATTACH]2211548[/IMG]
The upper spar is cut into the size of the root part of the wing.
[ATTACH]2211550[/IMG]
Also on the upper part of the wing are pasted four more slats 2,5X3, 5 mm.
[ATTACH]2211552[/IMG]
Waiting for the glue to dry up depresses...
Faster Wind 04-24-2017 06:30 AM
25 Attachment(s)
[ATTACH]2211507[/IMG]
[ATTACH]2211509[/IMG]
[ATTACH]2211511[/IMG]
[ATTACH]2211513[/IMG]
[ATTACH]2211515[/IMG]
[ATTACH]2211517[/IMG]
[ATTACH]2211519[/IMG]
[ATTACH]2211521[/IMG]
[ATTACH]2211523[/IMG]
[ATTACH]2211525[/IMG]
[ATTACH]2211527[/IMG]
[ATTACH]2211529[/IMG]
[ATTACH]2211531[/IMG]
[ATTACH]2211533[/IMG]
[ATTACH]2211535[/IMG]
[ATTACH]2211537[/IMG]
[ATTACH]2211539[/IMG]
[ATTACH]2211541[/IMG]
[ATTACH]2211543[/IMG]
[ATTACH]2211545[/IMG]
[ATTACH]2211547[/IMG]
[ATTACH]2211549[/IMG]
[ATTACH]2211551[/IMG]
[ATTACH]2211553[/IMG]
[ATTACH]2211554[/IMG]
Faster Wind 04-25-2017 09:33 AM
25 Attachment(s)
All slats from the end of the root part are treated level, except for the lower side member, it is processed later.
[ATTACH]2211727[/IMG]
[ATTACH]2211728[/IMG]
[ATTACH]2211729[/IMG]
On the lower rails glued plywood corners.
[ATTACH]2211731[/IMG]
[ATTACH]2211733[/IMG]
On the top slats are also glued corners.
[ATTACH]2211737[/IMG]
[ATTACH]2211739[/IMG]
[ATTACH]2211741[/IMG]
The lower spar is cut to size before the end and one end is bent at an angle.
[ATTACH]2211743[/IMG]
[ATTACH]2211745[/IMG]
[ATTACH]2211747[/IMG]
[ATTACH]2211749[/IMG]
[ATTACH]2211751[/IMG]
Edge for the endings.
[ATTACH]2211753[/IMG]
[ATTACH]2211755[/IMG]
[ATTACH]2211757[/IMG]
[ATTACH]2211759[/IMG]
Lower rails, from the corners to the edge for the endings.
[ATTACH]2211761[/IMG]
[ATTACH]2211763[/IMG]
[ATTACH]2211765[/IMG]
[ATTACH]2211767[/IMG]
Top slats, from corners to ribs.
[ATTACH]2211770[/IMG]
[ATTACH]2211771[/IMG]
[ATTACH]2211773[/IMG]
The lobic on the end is different from the forehead in the root part, it is marked with a small hole.
[ATTACH]2211776[/IMG]
25 Attachment(s)
[ATTACH]2211730[/IMG]
[ATTACH]2211732[/IMG]
[ATTACH]2211734[/IMG]
[ATTACH]2211735[/IMG]
[ATTACH]2211736[/IMG]
[ATTACH]2211738[/IMG]
[ATTACH]2211740[/IMG]
[ATTACH]2211742[/IMG]
[ATTACH]2211744[/IMG]
[ATTACH]2211746[/IMG]
[ATTACH]2211748[/IMG]
[ATTACH]2211750[/IMG]
[ATTACH]2211752[/IMG]
[ATTACH]2211754[/IMG]
[ATTACH]2211756[/IMG]
[ATTACH]2211758[/IMG]
[ATTACH]2211760[/IMG]
[ATTACH]2211762[/IMG]
[ATTACH]2211764[/IMG]
[ATTACH]2211766[/IMG]
[ATTACH]2211768[/IMG]
[ATTACH]2211769[/IMG]
[ATTACH]2211772[/IMG]
[ATTACH]2211774[/IMG]
[ATTACH]2211775[/IMG]
Faster Wind 04-25-2017 09:40 AM
5 Attachment(s)
[ATTACH]2211777[/IMG]
Wing weight.
[ATTACH]2211778[/IMG]
Weight of the fuselage.
[ATTACH]2211779[/IMG]
Weight in the collection.
[ATTACH]2211781[/IMG]
[ATTACH]2211783[/IMG]
del.
ArcadeAir 04-26-2017 04:59 AM
Looks Good !
Faster Wind 04-26-2017 08:13 AM
20 Attachment(s)
The final element of the leading edge, 3 mm rails.
[ATTACH]2211878[/IMG]
[ATTACH]2211879[/IMG]
[ATTACH]2211881[/IMG]
[ATTACH]2211882[/IMG]
Tail tail is made of 4mm thick foam.
[ATTACH]2211884[/IMG]
Each element of two plates, the total thickness of 8mm.
[ATTACH]2211886[/IMG]
[ATTACH]2211888[/IMG]
Plywood parts with holes for the axis are pasted into the rudder of the direction.
[ATTACH]2211891[/IMG]
[ATTACH]2211893[/IMG]
On the planking plumage I used a balsa 1,5mm. Thick. For rounded edges, the balsa is cut with fibers across.
[ATTACH]2211895[/IMG]
[ATTACH]2211897[/IMG]
Front and back edges of the stabilizer made of balsa 3mm.
[ATTACH]2211899[/IMG]
[ATTACH]2211901[/IMG]
[ATTACH]2211903[/IMG]
The leading edge of the rudders, balsa 3mm.
[ATTACH]2211905[/IMG]
[ATTACH]2211907[/IMG]
[ATTACH]2211909[/IMG]
[ATTACH]2211911[/IMG]
[ATTACH]2211913[/IMG]
[ATTACH]2211915[/IMG]
Faster Wind 04-27-2017 07:01 AM
20 Attachment(s)
Sheathing of the fuselage.
[ATTACH]2212048[/IMG]
[ATTACH]2212050[/IMG]
[ATTACH]2212052[/IMG]
[ATTACH]2212055[/IMG]
[ATTACH]2212057[/IMG]
[ATTACH]2212059[/IMG]
[ATTACH]2212061[/IMG]
[ATTACH]2212064[/IMG]
[ATTACH]2212067[/IMG]
[ATTACH]2212069[/IMG]
[ATTACH]2212071[/IMG]
[ATTACH]2212072[/IMG]
[ATTACH]2212074[/IMG]
[ATTACH]2212076[/IMG]
[ATTACH]2212078[/IMG]
I glued the plumage skin.
The stabilizer had to be sewn with a solid plate,
only time was lost on these tricks with the fitting of the elements.
[ATTACH]2212080[/IMG]
[ATTACH]2212082[/IMG]
[ATTACH]2212084[/IMG]
[ATTACH]2212086[/IMG]
[ATTACH]2212087[/IMG]
Faster Wind 04-28-2017 10:18 AM
10 Attachment(s)
Finishing element of the leading edges of the tail.
[ATTACH]2212196[/IMG]
[ATTACH]2212197[/IMG]
[ATTACH]2212199[/IMG]
I in worked the height controls.
[ATTACH]2212201[/IMG]
I in worked the fuselage.
[ATTACH]2212203[/IMG]
[ATTACH]2212205[/IMG]
[ATTACH]2212207[/IMG]
I in worked the wing.
[ATTACH]2212209[/IMG]
Then the stabilizer and the rudder were still processed and everything was collected in a heap.
[ATTACH]2212211[/IMG]
[ATTACH]2212213[/IMG]
10 Attachment(s)
[ATTACH]2212198[/IMG]
[ATTACH]2212200[/IMG]
[ATTACH]2212202[/IMG]
[ATTACH]2212204[/IMG]
[ATTACH]2212206[/IMG]
[ATTACH]2212208[/IMG]
[ATTACH]2212210[/IMG]
[ATTACH]2212212[/IMG]
[ATTACH]2212215[/IMG]
[ATTACH]2212216[/IMG]
Calvinman 04-30-2017 04:59 AM
Wow, very light model, nice build! :D
Faster Wind 04-30-2017 09:18 PM
24 Attachment(s)
Continue the Assembly. I decided to install the equipment before you hang plenkoy.
[ATTACH]2212538[/IMG]
[ATTACH]2212539[/IMG]
Steering height via two traction.
[ATTACH]2212541[/IMG]
[ATTACH]2212543[/IMG]
[ATTACH]2212545[/IMG]
Balsa, in the places of attaching levers, impregnated with glue CA
[ATTACH]2212547[/IMG]
[ATTACH]2212549[/IMG]
[ATTACH]2212551[/IMG]
[ATTACH]2212553[/IMG]
[ATTACH]2212555[/IMG]
[ATTACH]2212557[/IMG]
We paste.
[ATTACH]2212559[/IMG]
[ATTACH]2212561[/IMG]
Pine corners to increase the cross-section of the suture.
[ATTACH]2212563[/IMG]
[ATTACH]2212565[/IMG]
[ATTACH]2212567[/IMG]
A hatch for access to the lower part of the fuselage.
[ATTACH]2212569[/IMG]
[ATTACH]2212570[/IMG]
Axle of the chassis, stud M4.
[ATTACH]2212572[/IMG]
[ATTACH]2212574[/IMG]
[ATTACH]2212576[/IMG]
[ATTACH]2212578[/IMG]
The tail wheel stand is in common with the rudder axis.
[ATTACH]2212580[/IMG]
[ATTACH]2212582[/IMG]
24 Attachment(s)
[ATTACH]2212540[/IMG]
[ATTACH]2212542[/IMG]
[ATTACH]2212544[/IMG]
[ATTACH]2212546[/IMG]
[ATTACH]2212548[/IMG]
[ATTACH]2212550[/IMG]
[ATTACH]2212552[/IMG]
[ATTACH]2212554[/IMG]
[ATTACH]2212556[/IMG]
[ATTACH]2212558[/IMG]
[ATTACH]2212560[/IMG]
We paste.
[ATTACH]2212562[/IMG]
[ATTACH]2212564[/IMG]
[ATTACH]2212566[/IMG]
[ATTACH]2212568[/IMG]
[ATTACH]2212571[/IMG]
[ATTACH]2212573[/IMG]
[ATTACH]2212575[/IMG]
[ATTACH]2212577[/IMG]
[ATTACH]2212579[/IMG]
[ATTACH]2212581[/IMG]
[ATTACH]2212583[/IMG]
[ATTACH]2212584[/IMG]
[ATTACH]2212585[/IMG]
Faster Wind 04-30-2017 09:22 PM
6 Attachment(s)
Thrust control carburetor.
[ATTACH]2212586[/IMG]
[ATTACH]2212587[/IMG]
[ATTACH]2212589[/IMG]
[ATTACH]2212591[/IMG]
[ATTACH]2212593[/IMG]
[ATTACH]2212595[/IMG]
6 Attachment(s)
[ATTACH]2212588[/IMG]
[ATTACH]2212590[/IMG]
[ATTACH]2212592[/IMG]
[ATTACH]2212594[/IMG]
[ATTACH]2212596[/IMG]
[ATTACH]2212597[/IMG]
Faster Wind 05-02-2017 07:05 AM
5 Attachment(s)
I covered it with a film.
Here is the link to the photo album:
https://fotki.yandex.ru/users/nazin8...m/564047/?&p=8
I added 38 photos.
[ATTACH]2212840[/IMG]
[ATTACH]2212841[/IMG]
Wing weight.
[ATTACH]2212843[/IMG]
[ATTACH]2212845[/IMG]
Weight of plumage.
[ATTACH]2212847[/IMG]
5 Attachment(s)
I added 38 photos.
[ATTACH]2212842[/IMG]
[ATTACH]2212844[/IMG]
Wing weight.
[ATTACH]2212846[/IMG]
[ATTACH]2212848[/IMG]
Weight of plumage.
[ATTACH]2212849[/IMG]
jester_s1 05-02-2017 03:10 PM
This is looking good, FasterWind. You seem to be the only person having problems with double posting. Would you mind telling me exactly what you are doing when you post? As in which button you push, how many times, etc?
Faster Wind 05-02-2017 07:35 PM
I do not even know what's wrong.
I write the text in the form of the answer, then I press post quick reply.
Maybe it's all in the photo? When I answer with plain text, everything is correct.
But when I upload photos, the messages are duplicated.
Faster Wind 05-03-2017 10:16 AM
15 Attachment(s)
Finishing assembly. I'm not going to upload all the photos, only the most interesting ones, I added 40 photos.
[ATTACH]2212996[/IMG]
The elevator are suspended on scotch tape.
[ATTACH]2212997[/IMG]
The elevator control system.
[ATTACH]2212999[/IMG]
[ATTACH]2213001[/IMG]
Axle of the rudder.
[ATTACH]2213003[/IMG]
Elevator control system.
[ATTACH]2213005[/IMG]
[ATTACH]2213007[/IMG]
Carburetor control system.
[ATTACH]2213009[/IMG]
[ATTACH]2213011[/IMG]
Connection of onboard electronics.
[ATTACH]2213013[/IMG]
Laying of giblets.
[ATTACH]2213015[/IMG]
[ATTACH]2213017[/IMG]
[ATTACH]2213019[/IMG]
Weight of the fuselage assembly.
[ATTACH]2213021[/IMG]
Weight without fuel 1130 gr.
[ATTACH]2213023[/IMG]
The flight is ready!
Link to photo album:
https://fotki.yandex.ru/users/nazin8.../564047/?&p=10
15 Attachment(s)
[ATTACH]2212998[/IMG]
[ATTACH]2213000[/IMG]
[ATTACH]2213002[/IMG]
[ATTACH]2213004[/IMG]
Axle of the rudder.
[ATTACH]2213006[/IMG]
[ATTACH]2213008[/IMG]
[ATTACH]2213010[/IMG]
[ATTACH]2213012[/IMG]
[ATTACH]2213014[/IMG]
[ATTACH]2213016[/IMG]
Laying of giblets.
[ATTACH]2213018[/IMG]
[ATTACH]2213020[/IMG]
[ATTACH]2213022[/IMG]
[ATTACH]2213024[/IMG]
[ATTACH]2213025[/IMG]
Faster Wind 05-05-2017 11:10 AM
They flew around! Impressions are more than joyful!
Just want to say, the time for flying around was not chosen correctly, the wind is not less than 7 m / s. But we were in the field, 40 km.
From the house and fly around, otherwise why come? : D
All that I can now say about the flight performance of the model:
Stability - despite the wind goes like a knife, the eared circuit works 100%.
Manageability - and the pitch and the course of the model reacts more than adequately and predictably. Personally, I shift the alignment still a little bit farther ahead, but perhaps this thought is due to the wind, since it is necessary to run against the wind at full throttle and the nose starts to pick up + the pitch is very sensitive.
The response - this surprised, probably because of the small scale, at the rate as if with ailerons!
Response to pitch, as already written, is redundant (most likely because of the alignment). I compare with the eared glider 3m.
Swing - he thought for a while before reacting to the stick.
The general impression - if to sum up, then I understand that it's too early to fly around without a wind, well, or at least not so strong.
Another impression is that you need to move the center forward 1 cm.
Another impression is that the engine can still be slightly lower down.
The rest is more than satisfied.
I will try not to delay with the second flight, in the evening without the wind. Video will try :)
Calvinman 05-05-2017 12:56 PM
Great flight Faster Wind, looks like you had some fun with that thing :)
Faster Wind 05-14-2017 08:11 AM
Flying without a wind!
Faster Wind 05-16-2017 10:13 AM
Faster Wind 05-26-2017 11:10 AM
I built this model for my son.
Today we went to practice for the first time.
