Wing not straight
One side of the wing was damaged after a crash. In rebuilding this side of the wing the dihedral became off by some 10 mm downward compared to the other wing side dihedral . Wing span is 72 inches .Do you think this situation will make the plane unstable? Cheers
The plane won't be unstable but the wing with less dihedral will lift more than the other wing, making it want to turn in the direction higher wing and difficult to turn in the other direction. Can you shim the wing saddle under the lower wing to even out the dihedral on both sides?
If you are talking dihedral you shim the wing saddle on the fuselage so the dihedral is even with the tail feathers? If so that is an easy fix your plane will just have a little less overall dihedral than before 5 mm per side and you will never know or feel the difference.
If you are talking twist in the wing or wash out/wash in you may be out of luck unless you tear apart the wing and rebuild it straight. Dennis |
Yes I am asking about dihedral not a wing twist .Thank you gentlemen very easy solution of using the saddle to balance the dihedral of the wings .Great
Many thanks , Riadh |
| All times are GMT -8. The time now is 08:25 PM. |
