RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   CA hinges on a used wing (https://www.rcuniverse.com/forum/beginners-85/11645341-ca-hinges-used-wing.html)
jigeye 03-12-2018 05:23 AM
SIG four star 60. Crashed and rebuilt a couple of times. Need to put CA hinges on the left side of one piece wing (right side already has them and they are good). Problem is the wing has already had CA hinges a couple of different times and the thin CA will not soak into wing.
1. It looks like since I have already done this a couple of times ("re-caed" and moved hinges up down wing) this idea is out.
2. I do have Robarts I could do {already know how to do these}, but I don't want to use them if I don't have to.
The main question is, can you use a thicker CA for a situation like this or there any other techniques when you run into a situation like this.
thanks.
RCFlyerDan 03-12-2018 05:44 AM
Hope you found the gear that you wanted at Graphtech. Since you have already moved the CA hinges up and down the trailing edge of the aileron mounting edge, and there isn't anymore room to cut another slot anywhere on the aileron or edge, then Robarts would be the best bet. Another thing you could do, is to replace the aileron and this way you have new wood. The edge on the wing may not have the space. There is usually a lot of edge there to install the CA hinges. All you need is 3 and they don't have to be close to the other previous hinges. Just spaced out enough to carry the stresses and load. Thicker CA doesn't work.
Maybe if you are having difficulty with the landings, maybe there is a more experienced guy at your field that could help you with landing techniques? It is very important to learn how to glide the plane to the ground. Guys that I have helped even getting into gas, didn't have good primary instruction and don't know how to glide the plane. The best glide is when the wing cord is parallel to the ground/horizon, since you live in hilly land. To practice this, take the plane several hundred to a thousand feet high, engine to idle, wings level and parallel to the horizon. During turns, the wing dumps lift, so keep your banks to no more then 20 degrees. This little exercise will help your basic piloting skills. When the plane is on final, you want a low angle steady descent. All you want to see is the leading edge of the wing coming down final. If you see the top of the wing, you are coming in too fast, if you see the bottom of the wing, you are getting too slow, or are too high to make the landing. Once you get it into the profile of a proper glide, don't touch it, other then to keep it level and coming on proper glide slope to touch down. Your flight controls may have too much throw for your abilities too and make it more difficult for the landing mode.
rgburrill 03-12-2018 11:02 AM
CA will not stick to CA. You can still use CA type hinges but use epoxy to glue them in. Pinch the end of a straw, scoop up some epoxy into the straw, insert it into the slot, even one that was used before and re-opend, then blow the epoxy in, then insert the hinge. It will work just fine.
JPMacG 03-13-2018 04:00 PM
I have faced the same problem several times. There is no way I could make a new slot through CA hardened balsa and keep it centered. I had to go with Robarts. Not my favorite, as they are time consuming to install (some will disagree).
jester_s1 03-15-2018 05:13 AM
Pinned hinges are my goto in that situation. Install them with epoxy and put a straight pin in each side for insurance. You can cut the pin flush and grind off the head if you want it invisible.
TomCrump 03-16-2018 03:10 AM
Add me to this list. It's what I do in this situation.
Stickslammer 03-16-2018 09:00 AM
I`ve used toothpicks after drilling a 1/16th hole with my finger drill.
