RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Dual control surface servos (https://www.rcuniverse.com/forum/beginners-85/11705117-dual-control-surface-servos.html)
Miketwoblues 02-09-2023 01:57 PM
Dear menbers
I'm building a large Balsa usa Phaeton 90, and the idea has arison that I will see a betterhandling/performing ship with the Saito 125 4cyc., if I use dual servos. I placed a over ride control servo saver on one of the pair of servos. Will it be adequate to prevent stripping of gears in a servo ?Also how much spring adjustment would be necessary?
Any inputs/opinions will be welcome!
scale only 4 me 02-10-2023 07:11 AM
IMO, you'd be better off just using a couple good hi torque metal gear servos like a hitec 645 should do it,
Which servos do you plan to use?
Miketwoblues 02-10-2023 07:39 AM
'ordered four digital, high torgue, metal geared servos
scale only 4 me 02-10-2023 07:47 AM
Well, although that is a large plane, it's not at all a high performance plane and the elevators are not that large. I doubt you really need any kind of a servo saver..
J330 02-10-2023 09:01 AM
I can't remember a stripped servo gear or failure from flying anything. Crashing, that's another matter. IMO I think you have servos you'll never have to worry about. Like Scale stated, the control surfaces on that model won't test the limits of your servos, and the only time I've seen anyone use a servo saver was on rudder / tailwheel control to limit any tail wheel shock transmitted to that servo. I personally never used one, got some sitting in a new package for a decade though for that rainy day I might need it.
Decades ago you could get airplanes as big as that Phaeton 90 when servo technology was quite primitive back then, and rated a fraction of the torque you purchased.
Limitations of those old servos weren't a major issue. I suppose if you're model goes 100 mph or you perform 3D stunts, high torque servos would be necessary.
I've been using standard servos with few exceptions meaning the used plane came with them, but I didn't choose to throw money into them thinking it's a weak link. Flying pylon racers, pattern planes, 1/4 scale, sport planes, .40 and .60 size, some pulled along rather nicely using 16,000 rpm Rossi engines, servos weren't a concern. I read more about high torque servos in recent years than ever before, as if suddenly its now a requirement. BS. I never said, "Oh my servos have reached their limit, I need to find a higher torque servo immediately."
Placing your pushrod clevis closer to the shaft of the servo with a round or 5 prong servo arm will be easier on the servo than the full arm length of the 4 prong servo arm.
End point adjustment can be set in your radio programming if you need more deflection but that plane doesn't need more than 100%.
I'd consider a high torque servos in a 3D model, or a plane that goes over 100 mph. Sadly most people fool themselves into thinking their sport plane can go that fast, and you walk over and see a lame OS FX .61 or AX .65 with a 12X6 prop. Do that math, a .60 sport plane will never see 100 mph unless it's going straight down off a cliff. Radar gun readings tell the truth and never feel the urge to exaggerate.
https://cimg4.ibsrv.net/gimg/www.rcu...2391648be4.png
Miketwoblues 02-10-2023 01:57 PM
Thanks for the reply
Mike
Miketwoblues 02-10-2023 01:59 PM
MG 995 digital, high torgue, metal gears.Thanks for the reply
Miketwoblues 02-10-2023 02:04 PM
Yes I had the override serco saver on one of the rudder servos. because the bipe has the tailwheel
Miketwoblues 02-10-2023 02:15 PM
Thanks for all the data. I'm afraid to admit how long this plane has been in the building. Balsa USA gave very little data for placment of engine, tank , or radio gear, so I've made beaucoup mistakes, plus my building table and moving place to place wreaked havoc on time available. Then Hangar9 discontinued the deep red of the fuselage and I have to strip/recover. Whew! I don't want to remove elevators or rudder to recover. 'hope I can leave a little covering between the control surfaces and the stabs for attachment of the new red covering. Sorry for venting!
Mike
P.S. how is my choice of the Saito 125 4cyc.? Thoughts?
J330 02-10-2023 09:10 PM
Plenty of power. I like Saito engines. Fun thing about 4 strokes, you can back flip them to start, and there isn't as much need for an electric starter.
Take a jug of fuel, manual pump, glow igniter and your plane. Leave the heavy flight box home.
