Servo Question
I'm in the process of building a Sig Kadet Mark ii kit and am well along in its construction but have run into a problem with the servos I'm trying to use. I have an older Futaba Conquest radio set up that I got for short money at a recent flea market. The radio set came with three S-148 servos that are functional but I'm going to need five servos ( Aileron, elevator, rudder, throttle, landing gear) to get my build in the air. I have several additional S-148s plus a receiver that I was given. The additional S-148s, as they operate on a different frequency than my radio and other servos, do not work and I was wondering if there is any way I can get a couple of these spares operational and incorporate them into the build?
Not sure what you mean by (servos operate on different frequency) should work the same from servo to servo??
Any of the standard Futaba servos ought to work just fine with your receiver. If it happens that the additional servos are dead (it happens sometimes) most of the standard Futaba servos should work. Actually most standard servos will work but be careful, I think it's Airtronics servos that have a different pin out. The Kadet isn't that picky about servos but you will want to use the same servo on both ailerons. Assuming that your second receiver is compatible with the Conquest transmitter you can probably find the correct receiver crystal on ebay. I have found that a cheap servo tester is a great tool to have when sorting through the Big Bag of Old Servos.
Thanks, Being really new at this, I wasn't sure if a servo from one radio set would work with another. I have some servos from the second set that don't work. I didn't know there was a servo tester available....that will be my next E-bay purchase.
Thanks for the response. My ignorance of the subject and a couple of apparently broken servos made me unsure as to whether a servo from one radio set would work with a different receiver.
Originally Posted by Bigdipper99
(Post 12771593)
The RCM Flight Training Course book put out by RC Modeler has lots of great info about building the your first plane, properly installing the radio and engine and learning to fly. A great resource that is still relevant today despite being almost 50 yrs.
And you only need four servos.
1. Aileron 2. Side rudder 3. Throttle 4. Elevator |
Jaka54 is right. Most planes hook the rudder and nose gear to the same servo.
David |
| All times are GMT -8. The time now is 08:44 AM. |
