RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   battery charging??? (https://www.rcuniverse.com/forum/beginners-85/12282-battery-charging.html)
PROP-WASH 01-30-2003 02:40 PM
battery charging???
i'm not sure if i am doing the correct way of keeping my batteries in good shape during this long, cold,
winter here in northern newyork. what i have been doing is once a month a check them with my voltmeter
if there down sometimes leave them on and run them out completely then recharge them to full again.
[24hrs or so]. or i'll just charge them up from where the are in charge. is this right i am using the charger
that came with the radio and rec. would you please explain to me what is ment when you cycle the batterys
is their a charging unit just for this. i have a fast charger for the field but i know this is not what is needed
for the cycling of the batterys so if some one could give me some pointers in this area would be great.[img]i/expressions/face-icon-small-happy.gif[/img]
Rodney 01-30-2003 03:23 PM
battery charging???
You will be doing yourself a favour by reading www.rcbatteryclinic.com and follow the advice given there. In general, when storing your batteries for the winter, just disconnect them and leave them alone; makes no difference whether you leave them charged or discharged. The important part is that when you are ready to use them again, give them a slow charge (c/10) for at least 15 hours. If you have a battery cycler, go ahead and check out their capacity after a long slow charge and replace any that fall below 80 % rated MAH. All Nicads have a lifespan and you use up one of those life cycles every time you discharge/recharge so why waste battery life. It is wise to check them every two or three month for capacity but any more often is just wearing them out. Do not worry about the so called memory effect, that is an old wives tale generated back in the early days of NiCads and later proven to be totally false. Yes, NiCads slowly loose capacity but that is not due to memory, just degradtion of the internal parts over time which is accelerated at the higher temperatures that can be caused by high discharge rates, excessive fast charging or other abuse.
