Dead Stick???
What does it mean "Dead Stick"??
RE: Dead Stick???
When you engine has failed and you are on the way down; the control stick has gone "dead".
RE: Dead Stick???
loss of engine during flight operations:D
And if not handled properly by the pilot in command followed by the term re-kitted plane:D |
RE: Dead Stick???
It means you're earning a glider rating, too. My first glow engine powered flight ended in a deadstick landing, BTW.
RE: Dead Stick???
I had such an unreliable( old, wornout, no compression.....) engine on my first plane that I only ever had 8 landings out of about 25 flights with the engine running.
RE: Dead Stick???
I fly electrics and I dead stick land the plane about 75% of the time by choice. Motor off but all surface control working. Partly I just like to do it and partly it gives me practice for when I keep the plane up too long and the battery dies in the air. I guess running out of fuel on a glo plane would be the same thing.
I also fly sailplanes and, by definition, I am always flying dead stick. No motor! :D |
RE: Dead Stick???
oh ok... thanks very much!!!
RE: Dead Stick???
the firts dead stick i had to tackle was quite easy.i had just taken of and it was about 20 meters in the airwhen the engin stoped.
RE: Dead Stick???
Deadstick--------a condition that can be rectified using viagra........[sm=bananahead.gif]
RE: Dead Stick???
ORIGINAL: steprman When you engine has failed and you are on the way down; the control stick has gone "dead". |
| All times are GMT -8. The time now is 09:52 PM. |
