warped ailerons
it seems that everytime i build a kit with solid stock ailerons, theyre always warped. im building a ss 60 and sure enough one aileron is bent in both directions, the other in just one. is there a fix ( wetting w/ ammonia and clamping, etc.) or should i toss them and build up another pair ?
RE: warped ailerons
That would work fine, ammonia, alcohol....anything that is volatile and wont let the wood to stay wet for a long time should do.
RE: warped ailerons
1 Attachment(s)
There are 3 ways that it can be warped. Only one needs to be corrected.
Looking at the pic below, only the TE in figure 1 needs to be straightened or replaced, the other two will straighten out when it is hinged in place. |
RE: warped ailerons
MinnFlyer, will the hinges hold on #3? I had one that was .25" out of whack and I had to push on it so hard I figured it would eventually pull the hinge loose. I replaced it but would try it the other way if it will hold.
RE: warped ailerons
Obviously, it depends on the strength of the wood. In most cases, only minor pressure would be required to hold it straight. After a short time, the wood would relax and the warp would disappear. But if it's an unusually strong piece of balsa, and needs a lot of pressure to get it straight, then I would replace it (or try the "wetting it and bending it the opposite way" method to try to straighten it)
| All times are GMT -8. The time now is 09:00 PM. |
