Inbuilt starter
Hi!
Has anyone ever seen or heard about an inbuilt starter that one could switch on from a TX and therefore start a plane's engine? No more fingers into propeller... |
RE: Inbuilt starter
If I remember correctly Byron had one for there big models years ago. Problem is on most smaller models the starter simply adds weight.
RE: Inbuilt starter
The new jet turbines(Bhotec, i think) have a digital mix where once you blip the throttle to full and back to idle the turbine is automatically started. No fuss, No worries
RE: Inbuilt starter
You'll occasionally see them advertised in some of the magazines. They're novelty items for the most part, as they just add a lot of weight and complication. Besides the starter motor and the batteries to run it you've also got to have a shaft connecting the starter, and a gearing/clutch to connect that shaft to the engine. You've also got to provide an on-board glow driver. They're not practical for most conventional models.
RE: Inbuilt starter
My opinion, having done it for a freind's 1/4 scale Cub.. don't bother.
Weight of motor to start engine (big - required to move piston past compression). Linkages / powertrain to connect motor to engine. Also need a support to hold motor. Batteries to power said motor (again, big - need quite a few electrons to power that motor!) and one channel & servo to turn on switch. For anything less than a 90 sized plane. Over kill. over weight. And the charge in the 4 'c' cells only allowed for about 3 or 4 starts. You still need a metod of 'igniting' the glow plug, and priming the engine... |
RE: Inbuilt starter
This is what you are looking for.
Would consider above comments wrt being worthwhile www.hobby-lobby.com/fema.htm Regards Steve |
| All times are GMT -8. The time now is 08:13 AM. |
