help me
What do you think about this for a beginner?
Great Planes PT-40 O.S. .46FX Futaba 6XAS S3004 Servos What propellers and glow plugs should I get? Thanks! |
RE: help me
That sounds like a good starting pack to me...if you are just getting into glow powered aircraft.
In the area of glow plugs.. find a glow plug that will fit your engine. a local hobby shop or online dealer sell glow plugs in different sizes. |
RE: help me
I will be starting in the spring with the avistar 6xas os 46 fx 3004 serveos 127 df receiver have G2 Lite to fly all winter
Also have instructor picked out |
RE: help me
Dittto what DFalpha said. In the area of field equipment this is what you'll basically need:
-spare propeller -spare glow plug -fuel pump or bulb -chicken stick -glow clip and battery -fuel -and a box to put all the goodies in:D This would be just a basic setup. Take a look at your LHS or visit your local club. Enjoy!:D |
RE: help me
what???
RE: help me
to R T W that is :D
RE: help me
is the avistar better than the PT-40?
RE: help me
Rersonel preferance PT-40 Has flat bottom wing and can be bought as a kit Avistar has a simisemetrical wing and is an ARF
RE: help me
Both look good to me.... avistar looks like a good ARF kit to start with.
RE: help me
You'll probably want a 10 x 6 prop and just ask your LHS what glow plug the recommend for that engine (but don't spend more than 5 or 6 bucks for it)
RE: help me
I re-started with a PT-40 last Jan. It is a good flying plane the LA .46 will be a plus. If you build a PT-40 build it with a sport wing. I suggest an 11x4 prop to start, it will help slow the plane down on final approach. The Avistar ARF with the LA .46 is also an excellent plane(my son is flying one) it is gentle enough for a trainer but more capable of more advanced flying. It would be my first choice. Just my opinion!!
RE: help me
PT 40 is a good choice, as is the Futaba 6XAS and OS 46 FX.
I'd get a 10 X 6, an 11 X 5 and a 12 X 4 prop. This will give you a decent range to try. OS A-3 glow plugs would be fine in that engine. Here's some info I've posted before in answer to questions about building materials and flight line equipment. Glues: 30 minute and 5 minute epoxy, with something to mix it on and with, (old plastic lids and wooden coffee stirrers, plus small plumbers' acid brushes). Thin CA. (Not "Superglue".) You can substitute wood glue for the CA, but it adds time to the build. Tools: XActo knife and extra number 11 blades. (Buy a box of 100, it's cheaper and you'll use them.) Razor saw; Kona or XActo. Kona is better. Steel straight edge, 18". A ruler will work but.... Sanding block and various grits of sandpaper. (80, 120, 200, 400.) Screw drivers, small and medium sizes, both flat and phillips types. Pliers, needle nose and regular. (At least one pair with side cutters for wire.) A good set of Allen or hex wrenches. (IMO, Ball drivers are a bit better if you can find a good set.) A "Dremel" type rotary tool will help a lot if you can shell out the extra dollars. Covering tools: A sealing iron. A Trim iron will help too if you can swing both. A Heat gun made for covering. (Blow dryers don't really get hot enough.) More of those #11 blades for your XActo knife if you didn't buy the box of 100. Check the kit (or ARF) contents. Most will have a list of extras you'll need to buy; like wheels, fuel tank (& size), fuel line, etc... By the way. You should buy the engine and radio equipment when you get the plane. You'll need them all to finish the plane, and in some cases, you’ll need them to get started. Buy an engine on the larger size of the recommended range. Some type of "flight box". (A plastic tool box of appropriate size and design works well. Some good ones at Lowe’s or Home Depot. A gallon of 10% fuel, a fuel pump, manual or electric and fuel line (3 feet minimum),. A glow igniter with charger. Although not 'necessary', I highly recommend a 12 volt starter for the engine, because most new engines are quite hard to start with a "chicken stick", and it’s one more headache you don’t need when beginning. If you buy a 'self contained' glow ignitor and starter, and a manual fuel pump, you won't need to buy a 12 volt battery with charger, nor a "power panel" to connect everything. (And you won't have cords dangling around your prop when trying to start the engine.) Then, get a few props of slightly different diameters and pitch (in the recommended range). The engine directions should give you a range of appropriate sizes for your engine. One or two extra glow plugs should last you through the learning process. The single most important thing that I would recommend getting is an instructor to help you learn to fly. They are also the single least expensive item you can get (free), and the single best piece of insurance that all your hard work building that plane will not be destroyed. Good luck and have fun. Dennis- |
| All times are GMT -8. The time now is 12:49 PM. |
