RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   ringed and non-ringed engine (https://www.rcuniverse.com/forum/beginners-85/1318331-ringed-non-ringed-engine.html)
ripzone 12-01-2003 09:06 AM
whats the difference between a ringed and non-ringed engine?
whats better?
Geistware 12-01-2003 11:50 AM
RE: ringed and non-ringed engine
A ringed engine has a steel ring making the contact with the cylinder .
A non-ringed engine has the piston making directo contact with the cylinder.
ORIGINAL: ripzone
whats better?
Montague 12-01-2003 12:00 PM
That's a good answer.
As for what's better, unless you are competing in something that requires the last little bit of power out of your engine, it doesn't matter, neither is better than the other.
That's not to say they aren't different, and that there aren't different "care and feeding" procedures for the different types that help your engine live longer. Also, note that there are actually several different styles of non-ringed engine. Most are ABC/N, but some (such as norvell and some Fox and K&B engines) are non-ringed but not ABC/N.
ripzone 12-01-2003 12:08 PM
what is ABC and ABN??
what does it mean?
Montague 12-01-2003 12:29 PM
ABC - Aluminum, Brass, Chrome
ABN - Aluminum, Brass, Nickle
An ABC/N engine has an Aluminum piston that rides in a Chromed(Nickle plated) Brass liner. The liner expands faster than the piston, creating the optimum compression seal.
ripzone 12-01-2003 12:33 PM
and what about ABL?
Montague 12-01-2003 12:51 PM
Where do you see ABL?
whstlngdeath 12-01-2003 10:34 PM
Check out Kyosho's glossary of airplane terms for such things as ABC, ABN, ABL and a host of other acronyms we are bombarded with in this hobby:
http://www.kyosho.com/glossary.html
Jesse
00000000000000 12-02-2003 12:18 AM
Here's ABL's homepage. Inquiring minds want to know right? [link=http://www.abl.com]Here is ABL's home page! Click This![/link]
Montague 12-02-2003 11:55 AM
From reading the Kyosho site, ABL would be the hokus-pokus OS came up with after their big black eye from their ABN engines that started pealing their liners. Early FX line engines had a real problem when overheated, the plating on the liner could flake off. A bad thing. It's apparently been fixed in the current FX engines.
For obvious reasons, I personally won't buy a used FX line engine (unless I know the owner, and the age of the engine), because as far as I know, there's no way to tell if it will have the liner problem or not.
In actual use, ABC, ABN, and OS's ABL are all the same thing.
rik756 12-02-2003 12:13 PM
Sounds like ABN is more of a marketing thing than a engineering thing lol.
Montague 12-02-2003 12:56 PM
I don't know enough materials engineering to know if there is an advantage to using nickle over chrome. I've always been under the impression that the guys who really KNOW engines prefer chrome and think the use of nickle is more of a cost savings thing than a real improvement in engine design. As I understand it, chrome is harder than nickle, and therefore wears better. However, like I said, I really don't know for sure, I could be way off here. I've never heard someone from OS (or otherwise "in the know") explain why they use nickle while everyone else uses chrome. It's a mystery. :D But the good news is that it really doesn't seem to matter in actual use. I happen to like OS engines, though I think they are bit over-priced.
