RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   spinner nut size (https://www.rcuniverse.com/forum/beginners-85/1329060-spinner-nut-size.html)
scolpit 12-05-2003 09:06 AM
spinner nut size
what spinner nut should i use on a OS 46fx with an APC 12x4?
Great Planes Aluminum Safety Spinner Nut 1/4"-28 ?????
Great Planes Aluminum Safety Spinner Nut 5/16"-24 ?????
Any other possible substitution?? Tks...
gus 12-05-2003 09:33 AM
RE: spinner nut size
46FX has a 1/4"-28 threaded crank shaft.
See manual page 36.
gus
gus 12-05-2003 09:37 AM
FWIW, the designation 14-28 means the crank shaft has a 1/4" outside diameter (it will fit into a 1/4 inch hole), and it has 28 threads per inch.
So, knowing that you are able to mate the spinner nut to the crank shaft. This does not help you to make sure that the nut is long enough to dighten fully on to the prop, but I would be really surprised if you find one with a problem.
Also, spinner nuts can be intentionally heavt because it makes sense that when you have a tail heavy plane, the most useful place to put counter-balancing weight is right n front of the prop. So, there are long, short, heavy, and light spinner nuts, all available in different threads.
gus
scolpit 12-06-2003 10:58 PM
tks a lot
danemcneill 12-22-2003 10:42 AM
Hi Guys - I had almost the exact same question and put my question in the Google search and was directed here.
Thanks much for your use of this board - helped be long after you guys finished.
Merry Christmas,
Dane
dr_wogz 12-22-2003 11:55 AM
But do watch what teh spinner nut is made of. some of teh 'heavy hubs' are brass, and will strip easier than hardened steel (the black nut that came with the engine)
