RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Covering issues (https://www.rcuniverse.com/forum/beginners-85/1472454-covering-issues.html)
nilo 01-27-2004 01:43 PM
Covering issues
I'm trying to change my trainner view to something better.
It's original covering is a white monocote or ultracote, I don't know to identify, and couple adesives building the drawings.
I removed the adesives leaving only the white covering and started applying the monocote.
The problem I found is, when applying the monocote over the existing white one, right when I heat with the iron or heat gun, there come up many bubbles, specially on areas where there isn't wood underneeth(wing). They come like some magic![&o]
Seems that when I'm applying the new monocote in areas where there is no old monocote (raw wood), the problem doesn't happen too hard.:eek:
Am I doing it right and is the monocote over monocote something recommended?
Nilo
BearcatPilot 01-27-2004 02:02 PM
RE: Covering issues
The best way to put apply monokote over monokote is to use the windex method. I can't explain it well enough, but if you do a search for it, you should be able to find the information.
Bax 01-27-2004 02:33 PM
RE: Covering issues
Top Flite MonoKote is a plastic film. It is leakproof, and won't let air pass through the film. When you try to apply one piece over another, any air trapped between the two pieces will show up as a bubble. There are basically two ways to prevent this:
1) Use an erasable marker to draw the outline of the trim piece. Starting about 1/8" inside the mark, poke lots of pinholes in the covering below. Very carefully iron-on the trim piece.
2) If the trim piece is large, start 1/8" inside the borders of the trim piece, and cut away all of the material underneath. Carefully iron-on the trim piece. When you go to shrink the trim piece, lay pieces of wet, rolled-up papwer towel on the seam. That will keep them from becoming loose while the rest of the area is heated. Make sure you apply the trim piece as wrinkle-free as you can. When you iron it on, some wrinkles will develop, but they'll go away when you shrink the middle. Large, multi-colored designs have been done this way.
The "Windex" method works for MonoKote Trim, because it has adhesive that doesn't need to be heated. If you use this method for regular heat-activated MonoKote, residual moisture between the pieces will vaporize and can cause bubbles.
With extreme care, and slow application, MonoKote can be applied over MonoKote without air bubbles, but this usually only works for fairly narrow pieces.
If you do get bubbles, they can be eliminated almost invisibly by *****ing them with a pin and then using a heat gun. The air will expand inside the bubble, and escape out of the pinhole. The colored adhesive will fill the pinhole for almost total invisibility. Heating with an iron doesn't work quite as well.
DBCherry 01-27-2004 03:43 PM
RE: Covering issues
You can also use the "Windex" method with standard Monocoate. The trick is not to heat it, or shrink it after the Windex dries. No ironing necessary, but you do have to go around the edges with Acetone or trim seal once the Windex dries.
Dennis-
