RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   servo question (https://www.rcuniverse.com/forum/beginners-85/1597992-servo-question.html)
whzyrd 03-06-2004 10:02 PM
servo question
i tried out my new tx today for the first time it is a JR 6102 it came with 5 537 servos 3 of them are whisper quiet and the other 2 make a bunch of noise there is no irugular movement but they are about 10 times as loud as the other 3 .Is this something i should
take back to where i got them or will they be fine
thank you in advance
Rich
FHHuber 03-06-2004 10:55 PM
RE: servo question
If a servo is making an unusual noise (and 3 servos being quiet... 2 of the SAME model being noisy... I'd call that unusual...) You probably should ask for replacements for the noisy ones.
I'm unfamiliar with the exact servo you have... most make a bit of noise. (gear whine.... digital servos have a STRANGE noise to them if yuo are not used to them...) If there's a loud grinding noise that is always a problem. Different servos make different noises.... but 3 being the same and 2 different with the same model servo... that is a good clue that you have 2 with problems.
CafeenMan 03-07-2004 02:21 AM
RE: servo question
Some servos are really loud. If they all are pretty much the same and work ok, then don't worry about it.
phread59 03-07-2004 12:06 PM
RE: servo question
I agree with FH. Get the servo's looked at. You sound like there is gear train problems.
Mark Shuman
