RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   engine starting question (https://www.rcuniverse.com/forum/beginners-85/1646925-engine-starting-question.html)
mburian02 03-21-2004 09:06 PM
1 Attachment(s)
ok, maybe this is gonna be a dumb question but not to sure.....when looking at the plane from the front which way does the engine turn to start it, clock wise or counter clock wise???? it is a tower .46
jsn 03-21-2004 09:37 PM
RE: engine starting question
the engine will spin/run counter clock wise when viewed from the front, many 2 stroke engines like a good prime and a Back flip (clock wise from the front) to hand start, if your using an electric starter then it must spin the engine counter clock wise.
John
rajul 03-21-2004 09:51 PM
If you're planning to hand start, please use a chicken stick. Hope you have one handy
Geistware 03-21-2004 09:52 PM
From the front, flip the top blade to the left!
mburian02 03-22-2004 12:46 AM
yes i do have a chicken stick, i was turning it clock wise and it was firing and trying to run but would only run for a second and then spit fuel out of the carb, will they do that running clock wise????
rajul 03-22-2004 12:51 AM
Get an experienced club member to help you tune the engine. You could do a search in the engine forum to get some idea how to tune the high and low ends. Always operate an engine with safety in mind.
