RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Hitec Trainer cord question (https://www.rcuniverse.com/forum/beginners-85/16656-hitec-trainer-cord-question.html)
jajube 04-30-2003 10:00 PM
Which trainer cord will work with a Hitec radio.
I would assume a Hitec trainer cord with another Hitec radio.
I ask because I am amazed at some of the tips and tricks that can be learned on this forum.
I've learned, never assume anything. Thanks!
FHHuber 05-01-2003 02:50 AM
Futaba Trainer cords will work with the Hitech radios.
However... The Hitech trainer cord has a diode protection built-in, The Futaba cord does not. When using the Futaba cord for Hitcech radios, turning on both power switches and then holding the trainer button (on either radio) can damage BOTH TX's!
The Hitech cord also works fine with the Futaba radios...
jajube 05-01-2003 09:16 AM
Thanks FHHuber for the excellent advice.
I would hate to see a couple of radios getting ruined by trying to save a few bucks.
aeajr 06-22-2003 07:51 AM
Trainer cord warning from Hitec
http://www.hitecrcd.com/Support/TrainerCordWarning.htm
Important Information Regarding Trainer cord compatibility
To our valued customers,
While Hitec radios are known to be trainer compatible with other Hitec and Futaba systems, Hitec has determined that the two-way Futaba cord is not 100% compatible with our systems and strongly suggests it not be used at any time.
Our tests show that when the Futaba trainer cord is used with a Hitec radio the slave transmitter will emit an RF signal, thus creating a potentially dangerous interference situation, and in some cases will burn up components in the slave and or master radio.
Hitec suggests that only the one-way Hitec trainer cord (#58310) be used with Hitec radio systems for training. Failing to do so will void the customers warranty and could create a potentially dangerous situation. Hitec apologizes for any inconvenience this may cause, but the safety of our customers is our utmost concern.
