engine location
Hello,
I just re-kitted my four star. Beings I didn't get to the part of mounting the engine untill wee hours of the night I cut corners by not measure it close enough. Now the prop only clears the ears of the fuse by about 1/8". It will run, it doesn't hit, but will the engine being further back affect anything as far as the flight characteristics, aside from the CG? Wings |
RE: engine location
Nope- ;)
RE: engine location
As long as you get the CG right you're fine!
Dennis- |
RE: engine location
Just make sure you have the correct amount of engine thrust angle per the plans.
| All times are GMT -8. The time now is 03:38 AM. |
