How to use starter correctly ?
I have just bought a Sullivan Hi-Tork starter. I need to know how to use it correctly. Standing in front of the propeller, I have set the starter to turn clockwise so that it will bring the engine to a compression cycle and the subsequent combustion will turn the prop anti-clockwise. I notice that the torque of the starter is not enough to turn the prop beyond the compression cycle. Is this how it's supposed to work ? Or is the starter supposed to crank the engine through the compression cycle ? My engines are OS46FX and OS61FX. Appreciate help and enlightenment on this........... :)
Helpful tips
Don't wear any loose clothing that can be caught by the prop.
Be careful when turning the prop by hand... the engine can accidentally be started. Be aware of where your arms and hands are. (If it's your first time have someone at the field help you.) Make sure to pull out when you hear the "pop" from your 2-stroke I probably forgot a lot of things, but hope this helps! -Brian |
Further explanation needed......
Originally posted by AQ500 2. Turn the prop by hand clockwise until you can feel compression. Yes, I need to reverse my wiring and check the battery. I am using a 12V 5Ah wet cell and it could be undercharged...... :) |
To have some "Slack"
By turning the prop slowly "clockwise" until you just start to feel compression, you
are giving the engine a bit of rotation time before hitting the compression stroke while spinning it with the starter the right way(counterclockwise). Lots of the starters won't do much if you already have the engine on compression in the starting direction. Particularly if they have long leads and a weak battery. |
I have the same starter and it is a bit on the weak side. Follow the steps in the previous post...turn prop clockwise until there is resistance (without the glow igniter on) to give the starter a head start. Also with new engines they are sometimes a bit tight so you may have to hold the starter just off the spinner and let it spin up a bit...then push it on to the spinner and it will turn it over.
Originally posted by Terry Wallace I have the same starter and it is a bit on the weak side |
Using Kavan
My brother has been flying for years and he helped me get started by putting together a wish list for me to get started. He's been using the Kavan for years with no trouble. I put an OS 46FX in my SIG trainer and it turns it over like a dream. I have been harrassed by the some of the club members for having a wimpy looking little starter though :)
Being a rookie this is the only starter I've had, tried some of the other guys and they seem to be pretty bulky and have no more drive then the Kavan. |
carbon brush switch ?
Hi GP, How long does the carbon brush switch last on the kavan ? I know that Hobby Lobby carries the spares for kavan.
Kavan Brush Replacement
Haven't had mine long enough to worry about the brushes yet. I will ask my brother since he has used his for several years now...
And yes, I did mail order mine through Hobby Lobby Int. Will get back to you........... Had my maiden flight last week with my instructor. After he checked the LT-40 out, practice taxi's, he put it down the center line and it pulled up straight and true like a champ. It was fantastic seeing your first plane take to the air. I got about 5 minutes on the first flight at the 3 high level .. :D Have 3 total flights on it now and hope to try approaches this weekend to get the feel of it.......Keeping my fingers crossed (but still trying to figure out how to get me knees from knocking). |
I have had my Sullivan starter now for twenty years and it has never been repaired or taken apart. Does that tell you something?
Get rid of the cables tying you to the flight box battery and buy the Sullivan battery pack and case. It fits right to the starter and has 12 cells 14.4v. and is rechargeable. There is more than enough power to start most engines. Most of the Pylon Racing fraternity use this type of set-up. Ed S |
it's working now !!
Thanks to all for your great inputs ! I reversed my wiring, charged my wet cell and the starter works great now !! I did not cut the cable length as I need to justify my money spent on the power panel :p But I did change my original sullivan rubber insert to a silicone insert made by miller. Much better grip and supposed to last longer.....................
| All times are GMT -8. The time now is 04:46 AM. |
