RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Engine Size for this plane ???? (https://www.rcuniverse.com/forum/beginners-85/1763904-engine-size-plane.html)
DragonHeart 04-27-2004 01:45 PM
1 Attachment(s)
Hi Guys,
I picked this plane up for next to nothing its not the most attractive model as you can see but it will be fine for learning a few new moves and not having to worry if it meets the earth :)
I was told it was a Miniture Aircraft Company Kit called the 'Flying Machine' the wingspan is 44 inches i wanted to know would anyone know what engine size this will take ????? and a rought idea of the control throws i should use for this ?
Any help would be helpful :)
Thx
Crashem 04-27-2004 02:01 PM
RE: Engine Size for this plane ????
depends on its weight and how you want it to fly?
Without knowing more I'd guess .40-.50 2s
DragonHeart 04-27-2004 02:12 PM
Not sure of the weight yet, its very light as it has foam wings sheeted in a thin balsa and i want it a bit ballistic if possible :)
passion-4-3D 04-27-2004 04:17 PM
I would say a .40 2S would throw that plane around
DBCherry 04-27-2004 05:27 PM
A 44" wingspan? Then yes, I'd say a 40 wou;d be plenty.
Dennis-
FHHuber 04-27-2004 05:50 PM
Yep... .40 or .46, relatively low pitch long prop and go fly some 3D with it.
Definitevly NOT a trainer. If used as a trainer it will be toothpicks within seconds.
Gringo Flyer 04-27-2004 05:51 PM
As far as control throws I would just eyeball it at first staying towards the conservative side then increase from there. I tried setting up a plane that was given to me with large throws thinking, "hey I can handle it" Wow was it a squirel, I was lucky to get it down. Lesson learned, start with small throws and move up. Now that they plane is trimmed out I have the throws back up to max and it is a lot of fun. I also think a 40 size engine would be more than plenty for that plane.
