RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   are z-bends adequate (https://www.rcuniverse.com/forum/beginners-85/1806740-z-bends-adequate.html)
tamccain 05-11-2004 07:06 PM
I am putting together a SPAD(debonaire), and I am going to be putting the radio equip in soon. I am curious as to whether a zbend is adequate for the control linkage at the servo, or should I be putting another clevis on the servo end.
adam d 05-11-2004 07:17 PM
RE: are z-bends adequate
i use EZ canectors on my servos
Doug D. 05-11-2004 07:26 PM
Zbends will be adequate. They have been used on most models up to .60 sized and larger. For your needs they should work well indeed. Just make sure you have no binding issues.
FHHuber 05-11-2004 07:40 PM
Z bends are superior to EZ-Connectors... but learning to do a good Z is a little challenging.
The "U" or "J" bend is becomming popular... just a U-turn in the wire. Its easy to do.. and works as well as a Z. (and makes you wonder why you messed with the Z's...[&:]) I'm sure there is some reason the U wouldn't be wanted on a precision aerobatic plane... but they tend to use clevices or ball links at both ends of the pushrod. (which is better than any bent end.)
"EZ Connectors" have a bad reputation for slipping... its hard to properly torque the things' setscrews onto the pushrod. They also have been known to have the little plastic keeper thingy pop off allowing the thing to come out of the servo. The metal keepers, and the use of lock-tite can overcome these problems.
5_spot 05-11-2004 08:33 PM
Awaiting Approval to see if the zbends will work ?.
[sm=confused.gif]
FHHuber 05-11-2004 08:34 PM
Yep... doing stress analysis.:D
tamccain 05-11-2004 09:22 PM
I guess if he doesn't sign it within a certain amount of time it will become law.
I just hope he doesn't veto it.
Flypaper 2 05-11-2004 10:48 PM
I would trust Z bends above anything else. Been using them for 45 yrs in RC and havn't had a failure.
tamccain 05-11-2004 10:59 PM
Sounds great guys, looks like I will be using the zbends then. I have a little bit more equipment to buy, and then I will be flying with an instructor soon. YEAH
