RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Prop reaming (https://www.rcuniverse.com/forum/beginners-85/1824940-prop-reaming.html)
cruzomatic 05-18-2004 10:03 AM
Prop reaming
I need to ream out a prop, but don't have a prop reamer. Is there any other method that could be used? Drill bit maybe or should I just buy one.
thanks
riceh03 05-18-2004 10:09 AM
RE: Prop reaming
It depends on the shaft size. For the standard small engine with a 1/4" shaft you can use a 1/4" drill bit. I have done it by just using my hand to grip the drill bit and turning enought to just enlarge the hole without getting it too large so that the prop does not center itself on the shaft. You want the hole too large so that you can get a wobble when the prop spins. You will also want to balance the prop after reaming it.
cruzomatic 05-18-2004 10:13 AM
RE: Prop reaming
Shaft size is 1/4, engine is a Magnum .91FS wanting to mount a MA 13x8 3 blade.
Wayne Miller 05-18-2004 10:22 AM
RE: Prop reaming
HI,
I knew there was a post already covering this so I did a seach with the word REAMER.
There is a bunch of advise and different methods on prop reaming and you may want to do your own search and look through them.
The following is one of the posts.
http://www.rcuniverse.com/forum/m_91.../tm.htm#919449
Hope this helps.
Best regards,
Wayne Miller
cruzomatic 05-18-2004 10:25 AM
RE: Prop reaming
Thanks Wayne, I appreciate it. :D
5_spot 05-18-2004 05:46 PM
RE: Prop reaming
ORIGINAL: riceh03
It depends on the shaft size. You want the hole too large so that you can get a wobble when the prop spins. You will also want to balance the prop after reaming it.
"you want the hole too large " ,i hope this is a misprint or am i reading it wrong ?.
